6 Replies Latest reply on May 5, 2009 1:02 AM by SriramNatesan
    I am gettin an error
    SriramNatesan
      I am gettinga the following error when i deploy my file in tomcat
      Error #2048: Security sandbox violation:
      can some one help me: http://localhost:8080/answers-homepage/Main.swf cannot load data from https://localhost:8080/answers-homepage/messagebroker/amfsecure. url: 'https://localhost:8080/answers-homepage/messagebroker/amfsecure'"]
        • 1. Re: I am gettin an error
          Michael Borbor Level 4
          That is a security sandbox violation, the url root where yout swf is called isn't the same that your services are, http!=https.
          You could change your channels definition to not use secure amf , or write a cross domain file
          • 2. Re: I am gettin an error
            Gregory Lafrance Level 6
            Also keep in mind that sub-domains are considered different domains, so mySub.myCompany.com is considered different from www.myCompany.com, and a crossdomain.xml file is necessary.
            • 3. Re: I am gettin an error
              SriramNatesan Level 1
              Hey Thanks! But now i am facing different problem. Now i am able to get a correct re-direction but still facing a problem. I have put my error below. Let me know if you have any idea on this..
              did the following changes in the service-config.xml
                     <default-channels>
                         <channel ref="my-secure-amf"/>  <!-- This code needs to be UNCOMMENTED when using SSL   -->
                         <!--channel ref="my-amf"/-->                     <!-- This code needs to be COMMENTED when using SSL      -->
                      </default-channels>
              I also hardcoded the URL that is to be redirected in this service-config.xml file
                    <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                          <endpoint url="https://ido-dev.nielsen.com/homepg/answers-homepage/messagebroker/amfsecure" class="flex.messaging.endpoints.AMFEndpoint"/>
                           <properties>
                                <add-no-cache-headers>false</add-no-cache-headers>
                           </properties>
                      </channel-definition>
              The changes made in remoting-config.xml
                          <default-channels>
                  </default-channels>
              After making these changes I did the build and redeployed the application. And I found the following error
              [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 500: url: 'https://ido-dev.nielsen.com/homepg/answers-homepage/messagebroker/amfsecure'"]
                    at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::faultHandler()
                    at mx.rpc::Responder/fault()
                    at mx.rpc::AsyncRequest/fault()
                    at mx.messaging::ChannelSet/faultPendingSends()
                    at mx.messaging::ChannelSet/channelFaultHandler()
                    at flash.events::EventDispatcher/dispatchEventFunction()
                    at flash.events::EventDispatcher/dispatchEvent()
                    at mx.messaging::Chaninel/connectFailed()
                    at mx.messaging.channels::PollingChannel/connectFailed()
                    at mx.messaging.channels::AMFChannel/statuisHandler()
              • 4. Re: I am gettin an error
                       <default-channels>
                        </default-channels>
                             <properties>
                             </properties>
                            <default-channels>
                    </default-channels>
                • 5. Re: I am gettin an error
                  Does that channel definition exist?
                  • 6. Re: I am gettin an error
                    yes i does exist...
