3 Replies Latest reply on Sep 19, 2008 11:15 AM by heavywriter
    Close Button on auto-sizing pop-up
    CRO1 Level 1
      Greetings
      I am using RH7 to develop a WebHelp project. When I link from a topic to another topic I use the display in auto sizing pop-up option. Is it possible to add a close button on the pop-up? If so, how?
      I would like to visually inform the users how to close the pop-up, clicking outside the pop-up is not very intuitive.
        • 1. Re: Close Button on auto-sizing pop-up
          Hi there
          Note that clicking the popup itself will also close it. Because of that, one might think of using an image to serve as the "button". The problem here is that clicking an image on the popup isn't sufficient to close it!
          One possibility would be to create an image used as a background image in a special style sheet .CSS file. I'm thinking that because the image would be referenced that way, it may allow working as you want. I'll have to test that later.
          Just pondering out loud here... Rick
          • 2. Re: Close Button on auto-sizing pop-up
            CRO1 Level 1
            Thanks Rick,
            You are getting way ahead of me with respect to the background image in a special style sheet. I'll explain to my clients to click in the pop-up to close it.
            Regards,
            • 3. Re: Close Button on auto-sizing pop-up
              heavywriter
              You can add a button. Harder scripts require more detail on inserting, but this one's relatively easy.
              Insert a SUBMIT button, label it "Close Window", code attached (nevermind my styles!)...
