5 Replies Latest reply on May 4, 2009 9:26 AM by Ned Murphy
    Button Visabilty
    flynnc
         I am a flash movie template that I sue to track and control external flash movies.
      When I load a movie using the loadMovieNum("name of file1.swf", 50); into the template the first time I use the following code to hide the options for the next button on the template:
      this.next_but._visible = false;
      this.next_txt._visible = false;
      this.next_men_but._visible = false;
      The template waits until a function is called from the loaded movie and unhides the relevant next button dependant on other outcomes.
      function setswfq1acomp (){
         if (this.tracker51cor > 0){
               this.next_men_but._visible = true;  // show next button
               this.next_txt._visible = true;
         }else{
               this.next_but._visible = true;   // show next button
      This works fine on the first quiz frame, however on the next frame I unload the movie using:
      unloadMovieNum(50); // module 1b quiz
      and then load the next movie using the loadMovieNum("name of file2.swf", 50); into the same level.
      I use the same code as above to manage the buttons on this frame but this time the button is not visable on top of the movie, but if I hover over the area of the movie the button is active as if I click on this are of the movie it takes me to the correct location.
      I can't understand why the button visability works correctly the first time and not the second.
      Any help would be appreciated.
      Cheers
