1. Re: Total noob, need help
Paul Riggott May 3, 2009 2:46 PM (in response to Robdogg)One way of doing it would be to do all the scans and place the files in their own folder (jpg/tif/pdf)
Then you can run the following script that will create a new folder off the existing one and batch split all the files naming them existingFileName#001.png and put them in the new folder (edited)
#target Photoshop
app.bringToFront;
var inFolder = Folder.selectDialog("Please select folder to process");
if(inFolder != null){
var fileList = inFolder.getFiles(/\.(jpg|tif|psd|)$/i);
var outfolder = new Folder(decodeURI(inFolder) + "/Edited");
if (outfolder.exists == false) outfolder.create();
for(var a = 0 ;a < fileList.length; a++){
if(fileList[a] instanceof File){
var doc= open(fileList[a]);
doc.flatten();
var docname = fileList[a].name.slice(0,-4);
CropStraighten();
doc.close(SaveOptions.DONOTSAVECHANGES);
var count = 1;
while(app.documents.length){
var saveFile = new File(decodeURI(outfolder) + "/" + docname +"#"+ zeroPad(count,3) + ".png");
SavePNG(saveFile);
activeDocument.close(SaveOptions.DONOTSAVECHANGES) ;
count++;
function CropStraighten() {
function cTID(s) { return app.charIDToTypeID(s); };
function sTID(s) { return app.stringIDToTypeID(s); };
executeAction( sTID('CropPhotosAuto0001'), undefined, DialogModes.NO );
function SavePNG(saveFile){
pngSaveOptions = new PNGSaveOptions();
pngSaveOptions.embedColorProfile = true;
pngSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
pngSaveOptions.matte = MatteType.NONE;
pngSaveOptions.quality = 1;
pngSaveOptions.PNG8 = false; //24 bit PNG
pngSaveOptions.transparency = true;
activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
function zeroPad(n, s) {
n = n.toString();
while (n.length < s) n = '0' + n;
return n;
2. Re: Total noob, need help
Robdogg May 4, 2009 9:04 PM (in response to Paul Riggott)Dude, you are so the MAN. This is exactly what I needed!!! Many thanks.
The only change I made is in the following line:
var fileList = inFolder.getFiles(/\.(jpg|tif|png|)$/i);
I changed psd to png, since I don't care about psd files in this instance.
Now if someone can come up with a robot that can take photos out of the album and place them onto the scanner, that would be so sweet.
Regards
