5 Replies Latest reply on May 4, 2009 2:09 PM by fazstp
    Best lingo writing practices (if statement)
    MAC800
      Hello
      What is the best script if you have a case where you have multi 'if statements'
      Here is what I need to do. I have a serial device attached to my PC that can read if contacts have closure. The device has 32 closures. I have all communication (status of the contacts) being reported back as text (100-132  [each contact has its own number starting at 100])entered into a text field. Obviously more than one closure could be reported back as closed at once (so a 'else if' statement would not work)
      So the question is as far as best writing practices for lingo .... how does this look?
      on enterFrame
      if the text of member "contacts" contains "100" then set the text of member "contact1" to "Open"
      if the text of member "contacts" contains "101" then set the text of member "contact2" to "Open"
      if the text of member "contacts" contains "102" then set the text of member "contact3" to "Open"
      if the text of member "contacts" contains "103" then set the text of member "contact4" to "Open"
      if the text of member "contacts" contains "104" then set the text of member "contact5" to "Open"
      if the text of member "contacts" contains "105" then set the text of member "contact6" to "Open"
      end if
      end
        • 1. Re: Best lingo writing practices (if statement)
          Sean_Wilson Adobe Community Professional
          The way your code is written suggests no relationship between the clauses. For example, is it possible that  member "contacts" could contain both "100" AND "101"? In this case would you want to change both member "contact1" and member "contact2"? If not, then your code might have been written as an 'if' statement and a series of 'else if's.
          I'll suggest you drop the ancient verbose syntax (you don't say which version of Director you are using) and assume the second - that you only want to change one at a time. Here is your original re-written a little more concisely:
          on enterFrame
            tText = member("contacts").text
            if tText contains "100" then member("contact1").text = "Open"
            if tText contains "101" then member("contact2").text = "Open"
            if tText contains "102" then member("contact3").text = "Open"
            if tText contains "103" then member("contact4").text = "Open"
            if tText contains "104" then member("contact5").text = "Open"
            if tText contains "105" then member("contact6").text = "Open"
          end
          and here it is with some relationship between the clauses (so that only one of them will execute - the first that is found to be TRUE):
          on enterFrame
            else if tText contains "101" then member("contact2").text = "Open"
            else if tText contains "102" then member("contact3").text = "Open"
            else if tText contains "103" then member("contact4").text = "Open"
            else if tText contains "104" then member("contact5").text = "Open"
            else if tText contains "105" then member("contact6").text = "Open"
          end
          You could write the whole thing in a case statement, but I don't think there's much to be gained by doing so
          on enterFrame
            case TRUE of
              (tText contains "100"): member("contact1").text = "Open"
              (tText contains "101"): member("contact2").text = "Open"
              (tText contains "102"): member("contact3").text = "Open"
              (tText contains "103"): member("contact4").text = "Open"
              (tText contains "104"): member("contact5").text = "Open"
              (tText contains "105"): member("contact6").text = "Open"
            end case
          end
          • 2. Re: Best lingo writing practices (if statement)
            Production Monkey Level 3
            I would not run this code in an "EnterFrame" handler. At some point in your code you update the information in member("contacts"). I would not bother with that step and instead update the other fields at the point that the data is generated.
            I would rewrite your current code this way.
            on enterFrame
               repeat with Cnt = 1 to 32
                  if tText contains String(99 + Cnt) then member("contact"&Cnt).text = "Open"
               end repeat
            end
            • 3. Re: Best lingo writing practices (if statement)
              MAC800 Level 1
              Sorry .....  Director 11.0 && Windows XP
              And yes 100 & 101 could both be TRUE
              So.......  I should use the below ?
              on enterFrame
              end
              Thanks for the help
              • 4. Re: Best lingo writing practices (if statement)
                Yes, but I agree that #enterFrame is perhaps not the best event to respond to given how frequently it occurs. You didn't explain where this script is and how often it needs to run, so it's difficult to make any recommendation.
                • 5. Re: Best lingo writing practices (if statement)
                  fazstp Level 2
                  Or as a variation on Production Monkey's routine
                  on enterFrame
                  contacts = member( "contacts" ).text
                  repeat with contact = 1 to 32
                  if ( contacts contains string( contact + 99 ) ) then
                  member( "contact" & contact ).text = "Open"
                  else
                  member( "contact" & contact ).text = "Closed"
                  end if
                  end repeat
                  end
