8 Replies Latest reply on May 5, 2009 2:16 AM by IlyaG
    How do I use mouse events?
    IlyaG Level 1
      I didn't thought its going to be so hard but after digging in the help library I decide to post my question here:
      How do I use mouse click event in action script to locate the mouse coordination.
      This is what I been trying to do.
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
      width="100%" height="100%" backgroundColor="#eaf1f6"
      backgroundGradientAlphas="1.0,1.0"
      creationComplete="init()"
      <mx:Script>
      <![CDATA[
      import mx.effects.Move;
      import mx.controls.Alert;
      private function init():void
           mouse=new Sprite();
           mouse.addEventListener(MouseEvent.CLICK,mouseEvents);
      private function mouseEvents(e:MouseEvent):void
           Alert.show("I am alive");
      </mx:Script>
      Now where did I got wrong?
        • 1. Re: How do I use mouse events?
          _Natasha_ Level 4
          In your code you add eventListener to sprite, but sprite is not visible, so you never get this event.
          You can add
          <mx:Button label="Test click" click="mouseEvents(event);"/>
          or for your sprite
               mouse=new Sprite();
               mouse.graphics.beginFill(0xFF0000); // set red color to see this sprite
               addChild(mouse); // add to visible list of component
          • 2. Re: How do I use mouse events?
            IlyaG Level 1
            Its not working, when I am running the program it shouts with run time
            error:" Error #1034: Type Coercion failed: cannot convert
            flash.display::Sprite@607c821 to mx.core.IUIComponent."
            This is because of the addChild() line, so when I remove it, it should
            activate the mouseEvents(e:MouseEvent) and show me my msg
            Alert.show(e.currentTarget.toString()); but it's not as well.
            So I don't know what the problem once again I am sending you my code, maby
            there was some thing that I missed...
            <mx:Script>
            <![CDATA[
              private var mouse:Sprite;
              mouse=new Sprite();
            this sprite
                         addChild(mouse);
            </mx:Script
            • 3. Re: How do I use mouse events?
              _Natasha_ Level 4
              yep,
              it's written in docs:
              "Note: While the child argument to the method is specified as of type DisplayObject, the argument must implement the IUIComponent interface to be added as a child of a container. All Flex components implement this interface."
              Sprite doesn't implement this interface, so it's RTE.
              So you should use UIComponent instead of Sprite.
              private var mouse:UIComponent;
                           &n bsp;          private function init():void
                mouse=new UIComponent();
              this sprite
                           addChild(mouse);
              To locate position mouseEvent has properties: localX, localY (coordinates in local object - UIComponent at your code), stageX, stageY (global coordinates)
              Message was edited by: _Natasha_
              • 4. Re: How do I use mouse events?
                IlyaG Level 1
                Nop this is't working, Its not giving me the run time error but
                the mouseEvents(e:MouseEvent) is never been called.
                Some thing wrong with the click event, its doesn't getting any events at
                all.
                I really hope that you will be able to help me with this, now it does look a
                bit complicated.
                • 5. Re: How do I use mouse events?
                  _Natasha_ Level 4
                  ok, I'll send whole code. You must to draw something on UIComponent or set top, botton, width and height properties to see this component.
                  Or you can annd click event to application to see all click events.
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()" width="100%" height="100%">
                  <mx:Script>
                  <![CDATA[
                  import mx.core.UIComponent;
                       // there you must draw something! otherwise width and height will be 0, and nothing is shown
                               mouse.graphics.drawRect(10, 10, 100, 100);
                               addChild(mouse);
                  </mx:Script>
                  </mx:Application>
                  • 6. Re: How do I use mouse events?
                    ATIF FAROOQ Level 3
                       if you want to monitor all mouse Clicks within your Application
                    irrespective of on what object this event was dispatched then you can add
                    global event listener on your main Application like this
                    Application.application.addEventListener(MouseEvent.CLICK,mouseEvents);
                    or in your Application Tag like this
                    click='mouseEvents(event)'
                    • 7. Re: How do I use mouse events?
                      IlyaG Level 1
                      Tnx a lot now I understand how this is working, for my aplication I choose to add the event listener to my canvas, thank you!
                      • 8. Re: How do I use mouse events?
                        IlyaG Level 1
                        tnx Natasha for your time, I found the way now
