3 Replies Latest reply on May 6, 2009 3:44 AM by Amul Adagale
    HTTPService as URLStream
    Irulan82
      Hello to all,
      I'm connecting a flex application via xml to a php server.
      Because of the  response can spent a lot of time ...as 1:00 minute per consult, I would like to show a progress bar while the application is receiving data.
      It´s not possible with httpservice, that only throw the result event when the complete information is received.
      I´ve tried with urlstream class that have the progress event...but it  only work with a static file to download...
      It doesn´t work like a service with a buffer that is progressively being filled by the php server.
      I´ll apreciate your suggestion, Thanks.
        • 1. Re: HTTPService as URLStream
          Gregory Lafrance Level 6
          You could popup a progressbar when the request is made, and then close the progressbar in the result handler.
          • 2. Re: HTTPService as URLStream
            Irulan82 Level 1
            Thanks Greg,
            It can be a solution,  a  progressbar  going to to the beggining and to the end until the result is completed, but I´m afraid the user can feel the same as  "show busy cursor = true "  while he is waiting. So he can think the aplication is hung up.
            Because I can´t know how long it takes, I can´t  determinate the percent received information of  the completed response.
            Is for that  I thought in a label number being increase with the bytes received would  be a real representation of the actual progress.
            Regards,
            Ana
            • 3. Re: HTTPService as URLStream
              Amul Adagale
              Even I am facing a similar issue where I would like to show a progressbar which displays the actual progress of an httpservice and not just a busy cursor.  I have tried adding an event listener to the httpservice 'progress event' but it doesnt seem to be called at all. Could anyone please give any pointers to this ?
              Thanks in Advance
              Amul
