12 Replies Latest reply on Jun 10, 2009 5:41 AM by Threadstone
    Drill Down in Flex 3
    Threadstone
      Hello All,
      I have a Column Chart for which the data source is  mysql database.I'm using PHP to interact with the database.
      I need a Drill down example for this scenario.
      Can anyone provide this please.
      Many thanks..
        • 1. Re: Drill Down in Flex 3
          Michael Borbor Level 4
          This example shows you how to drill down in a chart.
          http://www.adobe.com/devnet/flex/samples/dashboard/dashboard.html
          It doesn't use a callback to PHP, but as you've already now how to do that, that won't be an issue for you.
          • 2. Re: Drill Down in Flex 3
            Threadstone Level 1
            Thank you Michael, Its a Good One.
            I tried doing my requirement, interacting to mysql using PHP. While drilling down a chart, I still face few issues.
            I have written "if" conditions in my PHP...when ever I click on the chart I send a parameter to my PHP file.
            Based on the parameter it executes SQL Queries and Returns XML.
            This Idea is not working...I still get an error which I'm not sure of.
            Can anyone help ?.
            Error: Unknown Property: 'invoice'.
            at mx.collections::ListCollectionView/http://www.adobe.com/2006/actionscript/flash/proxy::getProperty()[C:\autobuild\3.2.0\frame works\projects\framework\src\mx\collections\ListCollectionView.as:694]
            at mx.binding::PropertyWatcher/updateProperty()[C:\autobuild\3.2.0\frameworks\projects\frame work\src\mx\binding\PropertyWatcher.as:293]
            at Function/http://adobe.com/AS3/2006/builtin::apply()
            at mx.binding::Watcher/wrapUpdate()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\ binding\Watcher.as:182]
            at mx.binding::PropertyWatcher/updateParent()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\binding\PropertyWatcher.as:199]
            at mx.binding::Watcher/updateChildren()[C:\autobuild\3.2.0\frameworks\projects\framework\src \mx\binding\Watcher.as:128]
            at mx.binding::PropertyWatcher/updateProperty()[C:\autobuild\3.2.0\frameworks\projects\frame work\src\mx\binding\PropertyWatcher.as:302]
            at mx.binding::PropertyWatcher/eventHandler()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\binding\PropertyWatcher.as:325]
            at flash.events::EventDispatcher/dispatchEventFunction()
            at flash.events::EventDispatcher/dispatchEvent()
            at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()[C:\autobuild\3.2.0\frameworks\ projects\rpc\src\mx\rpc\AbstractInvoker.as:190]
            at mx.rpc::Responder/result()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\Responde r.as:43]
            at mx.rpc::AsyncRequest/acknowledge()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\ AsyncRequest.as:74]
            at DirectHTTPMessageResponder/completeHandler()[C:\autobuild\3.2.0\frameworks\projects\rpc\s rc\mx\messaging\channels\DirectHTTPChannel.as:403]
            at flash.net::URLLoader/onComplete()
            Thanks & Regards,
            • 3. Re: Drill Down in Flex 3
              Threadstone Level 1
              Somebody Halp me plzzzzz
              • 4. Re: Drill Down in Flex 3
                Attach your full project or post the whole code to see what's wrong.
                Sincerely,
                Michael
                • 5. Re: Drill Down in Flex 3
                  Threadstone Level 1
                  My PHP file returns something like this.
                  if($cust=="XXXX")
                  $Query= <--- SQL Query>;
                  /* fetching data and output as xml */
                  print "<invoice_details>\n";
                  while( $Row = mysql_fetch_object( $Result ) )
                  print "<invoice><inv_num>".$Row->inv_num."</inv_num>"."<po_num>".$Row->po_num."</po_num>"."<inv _date>".$Row->inv_date."</inv_date>"."<billing_from>".$Row->billing_from."</billing_from>" ."<billing_to>".$Row->billing_to."</billing_to>"."<curr>".$Row->curr."</curr>"."<vat>".$Ro w->vat."</vat>"."<inv_amt_wo_vat>".$Row->inv_amt_wo_vat."</inv_amt_wo_vat>"."<inv_desc>".$ Row->inv_desc."</inv_desc>"."<inv_submit_date>".$Row->inv_submit_date."</inv_submit_date>" ."<payment_terms>".$Row->payment_terms."</payment_terms>"."<due_date>".$Row->due_date."</d ue_date>"."<due_date_cust>".$Row->due_date_cust."</due_date_cust>"."<amt_paid>".$Row->amt_ paid."</amt_paid>"."<inv_status>".$Row->inv_status."</inv_status>"."<credit_note>".$Row->c redit_note."</credit_note>"."<credit_note_num>".$Row->credit_note_num."</credit_note_num>" ."<proj_desc>".$Row->proj_desc."</proj_desc>"."<cust_name>".$Row->cust_name."</cust_name>" ."<flcb>".$Row->flcb."</flcb>"."<days>".$Row->days."</days></invoice>\n";
                  print "</invoice_details>";
                  • 6. Re: Drill Down in Flex 3
                    Post your Flex code as well.
                    • 7. Re: Drill Down in Flex 3
                      Threadstone Level 1
                      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                      <mx:HTTPService id="get_ovduereport" url="http://localhost/inv_overdue-debug/inv_overdue.php"  method="POST" />
                      <!--<mx:HTTPService id="get_ovduereport" url="http://localhost/inv_overdue-debug/inv_overdue.php"  method="POST"  resultFormat="text" result="resultHandler(event)" />-->
                      <mx:Script>
                      <![CDATA[
                        import mx.controls.Alert;
                        import mx.validators.NumberValidator;
                           import mx.rpc.events.ResultEvent;
                                      /*HTTPService result callback*/
                                      public function resultHandler( event:ResultEvent ):void
                                          Alert.show("Result " + String( event.result ) );
                      private function datasend(Data:String):void {
                      /*Alert.show(Data);*/
                      var objData:Object = new Object;
                                                    objData.cust_name =Data;
                                                    get_ovduereport.send(objData);
                      </mx:Script>
                      <mx:Panel title="Column Chart" x="182" y="276" width="378" height="372">
                      <mx:ColumnChart id="myChart" dataProvider="{get_ovduereport.lastResult.invoice_details.invoice}" showDataTips="true" width="356" height="332">
                         <mx:horizontalAxis>
                            <mx:CategoryAxis
                                 categoryField="cust_name"
                         </mx:horizontalAxis>
                         <mx:series>
                            <mx:ColumnSeries
                                 xField="cust_name"
                                 yField="vat"
                                 displayName="Vat" width="5" click="datasend(get_ovduereport.lastResult.invoice_details.invoice.cust_name)"
                            <mx:ColumnSeries
                                      xField="cust_name"
                                      yField="days"
                                      displayName="Days" click="datasend(get_ovduereport.lastResult.invoice_details.invoice.cust_name)"
                         </mx:series>
                      </mx:ColumnChart>
                      <mx:Legend dataProvider="{myChart}"/>
                      </mx:Panel>
                      </mx:Application>
                      • 8. Re: Drill Down in Flex 3
                        Change the resultFormat to E4X
                        • 9. Re: Drill Down in Flex 3
                          Threadstone Level 1
                          Hi Michael, The line of code you are talking about is commented.....!
                          Please check once !
                          • 10. Re: Drill Down in Flex 3
                            Sorry I missed that, please next time you post code use the Syntax Highlighting - Java, this feature makes it easier to read code.
                            • 11. Re: Drill Down in Flex 3
                              Have you tried debuggin the event.result to see if it's getting filled properly.
                              • 12. Re: Drill Down in Flex 3
                                Threadstone Level 1
                                Hello Micheal,
                                Sorry for the late response.
                                I tried displaying the result as you suggested.
                                I'm getting   "[Object] [Object] "
                                I think still there is some problem.Do you have any other guesses.
                                or Can you just provide me an example on similar lines....along with the DB tables.
                                I'll try here..
                                Many thanks.
