3 Replies Latest reply on May 5, 2009 1:27 AM by Cherax79
    AntiAliasingEnabled - very low FPS
    Cherax79
      I have a problem with sprite("world3D").antiAliasingEnabled = true (AAE = true)
      I have only 1 box and 20 spheres in this world.
      Is it possible that when AAE = false my FPS is about 200 and with AAE = true FPS is about 35 ?
      AAE really slows performance so much ?
      Or is there any other way/method to have 3D models anti-aliased faster?
        • 1. Re: AntiAliasingEnabled - very low FPS
          Necromanthus Level 2
          First of all, the most important info is missing: your graphics card brand & model.
          Secondly, AntiAliasing enabled is a frame rate killer in any 3D application.
          And Finally, statements such as "I got 200 FPS" are suitable for teenagers,
          because in the "real world" your're limited by the monitor refresh rate (in most of the cases 60-75 Hz).
          In other words, you cannot see more than 60-75 frames per second no matter what's your FPS value.
          cheers
          • 2. Re: AntiAliasingEnabled - very low FPS
            Cherax79 Level 1
            Dear necromanthus
            Thank You for your reply.
            Good new for me is "AntiAliasing enabled is a frame rate killer in any 3D application"
            I didn't know about monitor limitations too.
            But still my "200 fps" isn't about how much my eye can see but how much my processor can do without Anti-aliasing.
            So... I'm still at the same point.
            How to get Anti-aliased (or pseudo-AA) models in any faster way?
            Im using D11 and graphic card is not important because I want to have this effect on any computer.
            Any Ideas please ?
            • 3. Re: AntiAliasingEnabled - very low FPS
              That's the main problem: the graphics card is VERY important here!
              For example if your 3D world contains 20 spheres, but each sphere has 5000 faces (polygons),
              it means 100,000 polygons per 3D world.
              The performance drop in case of AA enabled is significant, and you need a top graphics card to get a decent frame rate.
              cheers
