2 Replies Latest reply on May 4, 2009 6:04 PM by ntsiii
    How to Find the Index of Element in the XMLListCollection
    alice_data Level 1
      I have a burning question here, and I wonder if anyone has tried to do this.
      I have an XML file that is read into the xml collection, and for each of the names that appear in the file (pre-declared somewhere else) , I tried to remove the element.
        However, it either gives me -1, if I do trace(slc.getItemIndex(xml.@name).toString()); when they exist, or tell me #3594 as shown in the error below:
      Here is the code:
      private function checkBox_change(event:Event):void{
                 xlc = new XMLListCollection(searchResult..book);
                     len = searchResult..publisher.length();
                     for (idx=0;idx<len; idx++) {
                         if (checkBox[idx].selected == false) {
                                 for each (name in input_name2) {
                                 for each (xml in xlc){
                                 if ((xml.@name == checkBox[idx].label) && (xml.@pub == name)){
          trace(xml.getItemIndex(xml.@name).toString());
          //I get an error that says 3594: getItemIndex is not a recognized method of the dynamic class XML.
      Could anyone please give me some pointers on how to remove the desired element? I do know how to use splice.
      Thanks for your help.
      Alice
        • 1. Re: How to Find the Index of Element in the XMLListCollection
          Michael Borbor Level 4
          Alice you could do something like this
          delete myXML.(@ISBN=="4689997865")
          Sincerely,
          Michael
          El 04/05/2009, a las 11:54, alice_data <forums@adobe.com> escribió:
          do this.
          Here is the code:
          Alice
          • 2. Re: How to Find the Index of Element in the XMLListCollection
            ntsiii Level 3
            getItemIndex() requires you pass in a reference to an item in the collection, not a string.
            And it is a method of XMLListCollection (and arrayCollection), not a method of XML.
            Like Michael says, using an e4x expression directly with delete is the best way to go.  Note to use delete, you must use a direct expression.  You can't put the node you want to delete in a variable and then delete that.
