5 Replies Latest reply on May 5, 2009 10:46 AM by _Natasha_
    iconFunction with ByteArray as Image Source?
    Miggl Level 1
      Hi Guys and Gals,
      How can I convert my ByteArray image string into a CLASS object that I can return in a custom iconFunction?
      Here's what I have:
      private function showListIcon(item:Object):Class
           var result          :Class          = new Class();
           var decoder          :Base64Decoder     = new Base64Decoder();
           if (item.hasOwnProperty("photo"))
                decoder.decode(item.photo);
           else if (item.hasOwnProperty("logo"))
                decoder.decode(item.logo);
           result = decoder.??????????; //(was using decoder.toByteArray() here in other functionality)
           return result;
      Thanks!
      -Mike
        • 1. Re: iconFunction with ByteArray as Image Source?
          _Natasha_ Level 4
          Hi Mike,
          may be the correct way for resolve your problem is to override decorator for your component to render ByteArray instead of Class?
          • 2. Re: iconFunction with ByteArray as Image Source?
            Miggl Level 1
            Hi Natasha,
            Thanks for this idea. I am using a custom ItemRenderer on a List. I want to show a custom list icon using my iconFunction method. Do you have an example of overriding the decorator? I haven't done that yet (a whole lotta learning going on here).
            Thanks!
            • 3. Re: iconFunction with ByteArray as Image Source?
              _Natasha_ Level 4
              this can be implemented in your custom itemRenderer. You cannt' use iconFunction because the class is experceted as a return value, so it will be null.
              In you itemRenderer you showld create a bitmap to show icon (in override protected function createChildren():void)
              private var _myIcon:Bitmap;
              super.createChildren();
              _myIcon = new Bitmap();
              addChild(_myIcon);
              in set data(value:Object) function you need to change data for bitmap
              override public function set data(value:Object):void
              super.data = value;
              var bitmapData = new BitmapData();
              bitmapData.setPixels(new Rectangle(0, 0, ICON_WIDTH, ICON_HEIGHT), decoder.toByteArray());
              _myIcon.bitmapData = bitmapData;
              In updateDispalyList you should set position of Bitmap (x and y properties) and change visibility if needed.
              override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
              _myIcon.x = 0; // will be the first
              _myIcon.y = 0;
              // other components showld be shifted to _myIcon.width
              • 4. Re: iconFunction with ByteArray as Image Source?
                Miggl Level 1
                Hi Natasha,
                Thanks for your help on this. Right now your solution is a bit over my head as I don't understand all the details. I did manage to find a solution: I created a method called imageFunction which returns either a Class object or a ByteArray, depending on what is used:
                private function showListImage(item:Object):*
                     var result     :*;
                     [Embed(source="com/brassworks/assets/user.png")]
                     var userIcon     :Class;
                     [Embed(source="com/brassworks/assets/vendor.png")]
                     var vendorIcon     :Class;
                     [Embed(source="com/brassworks/assets/group.png")]
                     var groupIcon     :Class;
                     [Embed(source="com/brassworks/assets/role.png")]
                     var roleIcon     :Class;
                     [Embed(source="com/brassworks/assets/duty.png")]
                     var dutyIcon     :Class;
                     [Embed(source="com/brassworks/assets/location.png")]
                     var locationIcon:Class;
                     [Embed(source="com/brassworks/assets/resource.png")]
                     var resourceIcon:Class;
                          if (item.photo.toString().length > 0)
                               result = decoder.toByteArray();
                          else
                               result = userIcon;
                     else if ((item.hasOwnProperty("name"))
                          && (item.hasOwnProperty("company_id")))
                          result = groupIcon;
                          && (!item.hasOwnProperty("company_id")))
                          result = roleIcon;
                     return result;
                Please let me know if there would be improvements you would make to this; I hope I'm not doing something horribly aggrevious here.
                • 5. Re: iconFunction with ByteArray as Image Source?
                  _Natasha_ Level 4
                  your function is ok.
                  But using both Classes for embeded images and byteArrays will complicate itemRenderer - you need to show or hide default icon and canvas for rendering byteArrays.
                  You can ask questions if you don't understand the idea. I think you should read a part about custom itemRenderers in developer docs.
                  http://livedocs.adobe.com/flex/3/html/cellrenderer_1.html
