1 Reply Latest reply on May 5, 2009 10:19 AM by jendehaan
    Flash brush problem
    keith248
      OK i am using Flash cs4 and i am using crappy windows vista, and i am using my wacom tablet and when i use the brush tool i dont see the pressure sensitive tab which is making my lines uneven etc., do i need to reinstall flash.When i use flash on my other laptop it works does flash not like vista?
        • 1. Re: Flash brush problem
          jendehaan Level 4
          Make sure that you have the latest Wacom drivers installed and active (tablet plugged in, etc), and then restart Flash. I have found that sometimes the driver sometimes becomes non-responsive. You shouldn't need to reinstall Flash (I've never had to, so far for me it has always been the driver).
          If you're on a Mac, you can try drawing something and then just de/reselecting the Brush. Sometimes it doesn't "take" on the first go (this is very intermittent, and doesn't occur on all machines - so a bit of a long shot).
          Regards,
          Jen.
