1 Reply Latest reply on May 5, 2009 5:14 AM by Ghe1982
    [Beginner Question] Problem configuring channels
    Ghe1982
      I am completely new to AdobeFlex3 and I am trying some simple test invoking java classes.
      I started from the BlazeDSTurnkey and Flex3 Builder, and I ran succesfully some of the examples.
      To make my own tests, I created a new project called "ematest", configured in the folder "C:\BlazeDS\tomcat\webapps\ematest" with FlexBuilder.
      I created a simple button that invokes my java class on click and I encounter this problem:
      when I click the button, I get this error:
      [CODE]
      [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'http://127.0.0.1:8400/ematest/messagebroker/amf'"]
      at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::faultHandler()[C:\autobuild\3.2.0\frameworks\p rojects\rpc\src\mx\rpc\AbstractInvoker.as:220]
      at mx.rpc::Responder/fault()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\Responder .as:53]
      at mx.rpc::AsyncRequest/fault()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\AsyncR equest.as:103]
      at mx.messaging::ChannelSet/faultPendingSends()[C:\autobuild\3.2.0\frameworks\projects\rpc\s rc\mx\messaging\ChannelSet.as:1482]
      at mx.messaging::ChannelSet/channelFaultHandler()[C:\autobuild\3.2.0\frameworks\projects\rpc \src\mx\messaging\ChannelSet.as:975]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.messaging::Channel/connectFailed()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\m essaging\Channel.as:997]
      at mx.messaging.channels::PollingChannel/connectFailed()[C:\autobuild\3.2.0\frameworks\proje cts\rpc\src\mx\messaging\channels\PollingChannel.as:354]
      at mx.messaging.channels::AMFChannel/statusHandler()[C:\autobuild\3.2.0\frameworks\projects\ rpc\src\mx\messaging\channels\AMFChannel.as:390]
      [/CODE]
      In fact I think it is something related to the channel configuration, but I just copied the "Test Drive Sample 3" configuration files (changing only the "remote-config.xml" to point my java class), so the channel configurations aren't changed.
      Can someone help me ?
      Thanks.
        • 1. Re: [Beginner Question] Problem configuring channels
          Ghe1982 Level 1
          Ok,
          I solved the problem and I am posting here the solution.
          I missed the configuration of the "messagebroker servlet" in the web.xml file.
          Adding this:
              <!-- MessageBroker Servlet -->
              <servlet>
                  <servlet-name>MessageBrokerServlet</servlet-name>
                  <display-name>MessageBrokerServlet</display-name>
                  <servlet-class>flex.messaging.MessageBrokerServlet</servlet-class>
                  <init-param>
                      <param-name>services.configuration.file</param-name>
                      <param-value>/WEB-INF/flex/services-config.xml</param-value>
                  </init-param>
                  <load-on-startup>1</load-on-startup>
              </servlet>
              <servlet-mapping>
                  <url-pattern>/messagebroker/*</url-pattern>
              </servlet-mapping>
          To the web.xml file will solve the problem.
