11 Replies Latest reply on Oct 4, 2006 12:39 PM by Newsgroup_User
    aligning layers
    dbjevans1 Level 1
      Hi, I use dreamweaver to design websites mainly for friends non professionally. My problem is this; I am used to building sites which build up from the top left hand corner, i.e with a menu and title bar. However, I've been asked to create a site based around a graphic which needs to be centered on the browser, but with text over the top. I can center it fine, but I can't work out how to align or nest the text layer above the image so that when I resize the browser window it stays in the same place relative to the image thats behind it. The image is in the center cell of a one row, three coloum table which enables me to center it. I have drawn the text in as a layer on top of this.
      Many thanks for your help
      David
        • 1. Re: aligning layers
          Level 7
          Read this page to learn about layers -
          http://www.great-web-sights.com/g_layerlaws.asp
          I sense you are standing on the rim of a high precipice....
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "dbjevans1" <webforumsuser@macromedia.com> wrote in message
          news:eg03ct$qtu$1@forums.macromedia.com...
          > professionally.
          > top
          > to
          > browser,
          > to
          > browser
          > The
          > me
          > David
          • 2. Re: aligning layers
            Level 7
            On Wed, 4 Oct 2006 10:45:49 +0000 (UTC), "dbjevans1"
            > David
            Try applying - via CSS - the image as the background for your table
            cell. Either that or you can do it via layers, but I would read the
            link Murray supplied.
            • 3. Re: aligning layers
              Level 7
              That's a very bad and sure to fail recommendation - did you not read any of
              the discussion?
              "Mister Mustard" <mustard@hotdog.com> wrote in message
              news:4qe7i2li959tknvok64thu6g1j8q7kg40i@4ax.com...
              >>professionally.
              >>top
              >>to
              >>browser,
              >>to
              >>browser
              >>The
              >>me
              >> David
              • 4. Re: aligning layers
                Level 7
                On Wed, 4 Oct 2006 10:04:37 -0400, "Murray *ACE*"
                >the discussion?
                Good morning, Murray, I'm not sure what discussion you are referring
                to. I read the original post in this thread, are you talking about
                something else?
                • 5. Re: aligning layers
                  Level 7
                  I'm talking about the posts following that. It's simply not possible to
                  succeed with a web page design that relies on a large background image of
                  the page layout and superimposed text.
                  news:4ng7i2dm6omsban2pbc2kv7ue8j7c9p4un@4ax.com...
                  >>of
                  >>the discussion?
                  > something else?
                  • 6. Re: aligning layers
                    Level 7
                    On Wed, 4 Oct 2006 10:24:31 -0400, "Murray *ACE*"
                    That will depend on the image and expectations. I was suggesting the
                    possibilities so OP can see the results and make decisions about how
                    to approach the problem.
                    • 7. Re: aligning layers
                      Level 7
                      Any attempt to align text with a background image will fail....
                      One tick change in the size of text will misalign everything.
                      news:92h7i2pf3207rvu6jvpio9fsqllefvlvmv@4ax.com...
                      • 8. Re: aligning layers
                        Level 7
                        On Wed, 4 Oct 2006 13:40:09 -0400, "Murray *ACE*"
                        Been done many times. Give it a try and you'll see the limitations.
                        Work within those and there is no problem.
                        • 9. Re: aligning layers
                          Level 7
                          It's a bad suggestion.
                          news:v2u7i2l1idkq7gsvqomhskhdda3d2vbeq2@4ax.com...
                          • 10. Re: aligning layers
                            dbjevans1 Level 1
                            hi
                            firstly, I really appreicate the replies - I understand that compared to you I know very little about web design but I appreciate the time you've taken. I read the page on using layers, which basically implies that without a far more detailed knowledge of CSS I should give up and stop wasting everyones time. I have indeed tried setting the image as a background image in a cell, I've heard it suggested in other places and just as you say - it fails, without fail. So unless anyone has a great idea of how I can learn to do this quickly, does anyone know of a good reference book from which I can teach myself for future reference?
                            David
                            • 11. Re: aligning layers
                              Level 7
                              > without a far more
                              Not really. But it does mean that if you are serious about creating web
                              pages, you really must study HTML and CSS....
                              Try these:
                              http://www.projectseven.com/tutorials/css/qdmacfly/index.htm
                              http://www.macromedia.com/devnet/mx/dreamweaver/css.html
                              http://www.macromedia.com/devnet/dreamweaver/articles/tableless_layout_dw8.html
                              http://www.macromedia.com/devnet/dreamweaver/articles/css_concepts.html
                              news:eg11hp$4pi$1@forums.macromedia.com...
                              > hi
                              > you I
                              > I
                              > more
                              > time. I
                              > heard
                              > So
                              > future
                              > reference?
                              > Thanks
                              > David
