1. Re: Toggling between two button symbols
kglad May 5, 2009 4:45 PM (in response to theMikeD)assign the visible property of those buttons in your mouse handlers. if you don't understand how to do that, copy and paste your current mouse handlers.
2. Re: Toggling between two button symbols
theMikeD May 5, 2009 4:58 PM (in response to kglad)Thanks for the help, but I'm not sure what you mean, or how to check that. I've looked through the UI for visibility things and don't really see any. I'm a bit out of my depth here
Basically I have a movie clip with two frames. In frame one I have a instance of PauseBTN, and in frame two an instance of PlayBTN. Currently, when I click on this clip, the slideshow stops and plays appropriately, and the normal state of the button is shown. It's just the rollovers that are not working.
What can I provide you so that we can figure this out?
...Mike
3. Re: Toggling between two button symbols
kglad May 5, 2009 5:10 PM (in response to theMikeD)that's not a flexible setup. PauseBtn should be a movieclip with an up,over and possibly down frame and PlayBtn should be a movieclip with an up, over and possibly down frame. you can then use:
PauseBtn._visible = true; // or false ot control your button's visible property.
4. Re: Toggling between two button symbols
theMikeD May 5, 2009 5:34 PM (in response to kglad)Both PlayBTN and PauseBTN are buttons, not movieclips, and each button has the three states set. Do you mean that I should recreate them as moviclips instead of buttons?
Assuming what I have is corrent, based on what you said, I should do the following:
1. Stack the two buttons one on top of the other. The PlayBTN instance is named PLAY and the PauseBT instance is named PAUSE.
2. Write code to set the initial visibility state of PLAY._visible to false
So when the SWF starts, PLAY is invisible, PAUSE is visible and the slideshow is playing.
3. write code so that PAUSE.onMouseUp() stops the slideshow, makes this._visible false, and PLAY._visible to true
So at this point, PLAY is visible and the slideshow is stopped.
4. write code so that PLAY.onMouseUp() starts the slideshow, makes this._visible false, and PAUSE._visible to true
Does that sound right?
...Mike
5. Re: Toggling between two button symbols
Ned Murphy May 5, 2009 6:02 PM (in response to theMikeD)What you describe in the case of using buttons should be fine. If you use movieclips, then you also need to include code to direct the currently visible button/mc to the different frames for the different states.
6. Re: Toggling between two button symbols
kglad May 5, 2009 6:12 PM (in response to theMikeD)1. yes
2. yes
3. no. don't use onMouseUp, use onRelease.
4. " "
that should work.
7. Re: Toggling between two button symbols
theMikeD May 5, 2009 6:17 PM (in response to theMikeD)Thanks so much guys, that did the trick
...Mike
8. Re: Toggling between two button symbols
kglad May 5, 2009 9:04 PM (in response to theMikeD)you're welcome.
