This content has been marked as final.
Show 5 replies
1. Re: Display Filtering
Newsgroup_User Sep 12, 2008 10:28 AM (in response to James_PT)Sure. You could either do it with a Spry dataset (that would be done client
side - and don't ask me how!), or by having an onchange event on the
list/menu <select> tag that submits the form to the same page. Have server
scripting in the head that parses out the selected value and uses that as a
filter in the SELECT statement.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"DreamerJim" <webforumsuser@macromedia.com> wrote in message
news:gae7k4$56p$1@forums.macromedia.com...
>I would like to place a drop down list box (menu) above a table that
>displays a
> few values (e.g., Open, Closed, etc.), so that when a user selects one of
> the
> values, the associated records in the table are filtered (only open, only
> closed, or all). I've tried doing this with a column variable in the SQL
> record select but can't quite seem to get it to work.
> Anyone done this?
2. Re: Display Filtering
James_PT Sep 12, 2008 10:37 AM (in response to Newsgroup_User)but what value would you set the filter to in order to get all the records again (options = Open, 'O', Closed 'C', or All???)
I can pass the 'O' for open, but for all? Sounds like it may take coding to remove that portion of the Where clause when not needed? -
3. Re: Display Filtering
Newsgroup_User Sep 12, 2008 10:46 AM (in response to Newsgroup_User)You have a status field in the database, right? You filter on that field.
news:gae9gl$75d$1@forums.macromedia.com...
> to
4. Re: Display Filtering
James_PT Sep 12, 2008 11:29 AM (in response to Newsgroup_User)Yes, I have a status field with an 'O' for Open and a 'C' for Closed, a 'P' for Pending, etc. I can filter on one of the values, but what happens when a user wants them all? For example, they first pick 'Closed', then they want them all. Selecting an 'All' option from the list is ok, but what value would be set in the parameter to essentially nullify the filtering effect and get all rows again? -
5. Re: Display Filtering
Newsgroup_User Sep 12, 2008 11:38 AM (in response to Newsgroup_User)In the case of "all" you would not add the WHERE clause to the SELECT
statement. Alternatively you could just use "%" I believe.
news:gaechr$afj$1@forums.macromedia.com...
> 'P' for
> user
> them
> be
> all
> rows again?
