3 Replies Latest reply on May 6, 2009 10:53 AM by kglad
    Passing MC not as good as hard coded
    StupidHuman
      I've got a transition after clicking on a moie clip that goes like this:
      var scale = 800;
      var speed = 61790;
      onEnterFrame = setInterval(fadeFrame,100,mcName);
      function fadeFrame(mc:MovieClip)
          mc._alpha -=5;
          if(mc._alpha <= 0)
          mc.alpha = 0;
          gotoAndStop(houseNumber);
      The mcName variable is a Movieclip delared in the first frame, and set with the name of a movieClip in the onRelease of a button instance:
          _root.mcName = adjustable1;
          _root.gotoAndStop(2);
      It does take the variable into the FadeFrame function, but doesn't work.  It comes out in trace as undefined with the _alpha property.  If I hard code the movieClip name into the setInteval it has no problem.  Any reason why it doesn't want to operate on the movieClip alpha this way?
        • 1. Re: Passing MC not as good as hard coded
          your first problem is with:
          that should be something like:
          fadeFrameI = setInterval(fadeFrame,100,mcName);
          your 2nd problem, if you decide to use setInterval(), is you must clear it:
          if(mc._alpha<0){
          // do whateveer
          clearInterval(fadeFrameI);
          third, it's not clear you're executing that code on the _root timeline.  if you're not, you should use _root.mcName, instead of mcName to pass to fadeFrame().
          • 2. Re: Passing MC not as good as hard coded
            StupidHuman Level 1
            The onEnterFrame worked find when I had the instance name of the movieClip hard coded rather than passing a variable(mcName) into the setInterval.
            Even when explicitly setting the _root.mcName when calling setInterval, it doesn't function properly.  A trace confirms it is getting the movie clip.  The movie clip is attached in the onRelease function before the gotoAndStop() that is sending the file into this frame.
            • 3. Re: Passing MC not as good as hard coded
              show your corrected code.
