0 Replies Latest reply on May 6, 2009 2:30 PM by ethr
    plotchart - bug?
    ethr
      Im wanting to use a PlotChart but have run into the following problem: its defaulting to all black with black text! I have several of these charts in my application and only one is having this problem. Here is the code:
      <mx:PlotChart width="100%" height="100%"
                  id="x10_2_PlotChart" paddingBottom="0" paddingLeft="0" paddingTop="0" paddingRight="0">
                  <mx:series>
                  <mx:PlotSeries xField="fullDate" yField="nameLoc"/>
                  </mx:series>
                  <mx:verticalAxis>
                      <mx:LinearAxis id="vaxis" labelFunction="x10_2_LabelFunction" />
                  </mx:verticalAxis>
                     <mx:horizontalAxis>
                      <mx:DateTimeAxis />
                  </mx:horizontalAxis>
      </mx:PlotChart>
      This is the only chart where I'm using the DateTimeAxis.
      The 'all black' version appears immediately when I load the form - before I set the dataprovider.
      I've tried changing various params in hope of understanding what I've set wrong. Setting / changing the data provider doesn't fix it.  My labelFunction returns "" if the data hasn't been loaded yet.
      It appears to be random. Im trying to be systematic about getting a repro case but making changes in other (unrelated) parts of the code can cause the problem to go away / return.
      Im guessing that the alpha has gotten set in some odd space. If I change it to .5 at design time I get a usable chart with a greenish background. I can see the text now though. Its not a solution though. I tried adjusting the 'blendmode' too. No luck.
      Im doing something completely silly and I can't see it. Set me right and laugh all you want.
