1 Reply Latest reply on May 7, 2009 6:44 AM by Gregory Lafrance
    Problem with HSlider
    wiz_rob
      I have a HSlider in my app which is supposed to have multiple snapIntervals.These intervals change depending on the slider value.eg if the slider range is
      25000 to 500000 from 25000 to 100000 the snapinterval will be 5000.Similarly from 100000 to 250000 the snapinterval will be 10000 and from 250000 to 500000 the snapinterval will be 25000.So when the event is triggered on slider change these intervals are set.The problem occurs at the transition points like when the slider value = 100000 the next expected value should be 110000 but the slider value reads 105000 and thus slider values get disturbed for the next range.Similar thing happens with the next transition.
