1 Reply Latest reply on May 7, 2009 5:46 AM by _Natasha_
    Problem with drag and drop in advanced datagrid
    rjoshicool Level 2
      I am dragging an item from a datagrid and dropping it in an advanced datagrid. The ADG is having a tree like structure. I am handling the dragDrop event of the ADG to do so. How can I get to know the parent of the node where I drop the item from datagrid?
        • 1. Re: Problem with drag and drop in advanced datagrid
          _Natasha_ Level 4
          as an example:
          // newView - destination datagrid
          // I use XML as a dataSource
          private function onDragDrop(event:DragEvent):void
          var drgData:Array = event.dragSource.dataForFormat(event.dragSource.formats[0]) as Array;
          var drgNode:XML = drgData[0];
          var i:int = newView.calculateDropIndex(event);
          event.stopImmediatePropagation();
          // replace data to destination
          // item at that point you have droped data
          var postNode:XML = newView.indexToItemRenderer(i).data as XML;
          // parent of this item
          var newParent:XML = newView.getParentItem(postNode);
          // here you can do what you want
