2 Replies Latest reply on May 25, 2009 12:17 AM by oGGo56
    PDF Generation with LiveCycle Data Services
    oGGo56 Level 1
      Hi everybody!
      I am using LiveCycle Data Services to generate a dynamic pdf. I worked with this tutorial : livedocs.adobe.com/livecycle/es/sdkHelp/programmer/lcds/pdfgen_1.html and i adapted the code to my own example.
      I created a pdf template with livecycle designer and i succeed to generate the pdf thanks to LiveCycle Data Services.
      Here is my problem :
      In LiveCycle Designer i create a table and bind my data connection (from xml source) to this table and i bind subforms to repeating data.
      It works when i try to open an overview of the pdf with LiveCycleDesigner.
      But when i try to generate the pdf with livecycle data service, there is no repeat of my data. There is only a number of items corresponding to the minimum of repeating i set in livecycle designer binding window...
      Is it possible to generate repeating data with LiveCycle DS ?
      an example of my xml source :
      <item id="1">
           <data>blabla</data>
      </item>
      <item id="2">
           <data>blabla</data>
      </item>
      In livecycle designer, if i set the minimum of repeating to 1,  LiveCycle DS generate a pdf with only one item.
      if i set the minimum of repeating to 2,  LiveCycle DS generate a pdf with only 2 items. etc.
      I don't know how to generate an indeterminate number of items...
      Thanks in advance for your help.
      Bye
      Guillaume
        • 1. Re: PDF Generation with LiveCycle Data Services
          MichaelChaize Adobe Employee
          Hi Guillaume,
          there is no limitation. Dynamic PDF files can be generated with Livecycle Data Services.
          You should have a look at the XML file generated by your Flex code. Try to save it and see how the XML file behaves when you generate a PDF preview with Designer. You can go to the menu:  File >  Properties > Preview > Use XML test data...
          With the XFAHelper class, you can either load a PDF or a XDP file. Have you tried with a XDP ?
          I've attached a dynamic PDF file that I've created for a customer. I generate a dynamic PDF file using LiveCycle Data Services. Maybe you'll find some clues within the file.
          Michael
          • 2. Re: PDF Generation with LiveCycle Data Services
            oGGo56 Level 1
            Hi Michael !
            Thanks for your response. Finally, I found the solution. It was not because of my XML, which was correctly generated. I saved my PDF template as a "dynamic PDF" instead of "static pdf" and it solved my problem.
            Guillaume
