4 Replies Latest reply on Sep 12, 2009 11:42 AM by Leonard B
    Cfwindow and variable
    RockDad Level 1
      I found an issue using Lightwindow 2.0 and CF8, therefore I need to find a different solution.  So I'm trying the cfwindow option but I am having a difficult time coding it to work the way I want.
      I am displaying query resultset which shows six different values and the URL is being appended by the uniquie ID of the record.
      How can I do this with cfwindow?
      This is what I have so far put it's not working at all.
      <cfwindow name="fcnews#NewsID#" title="" Width="500" Height="400" refreshOnShow="true" center="true" modal="true" source="news_detail.cfm?NewsID=#NewsID#"></cfwindow>
                        <a href="##" onclick="javascript:ColdFusion.Window.show('fcnews')">#Headline#</a>
      This opens the window but the data is imbedded in the page and not the window.
      Thanks in advance for your help.
        • 1. Re: Cfwindow and variable
          Leonard B Level 2
          Hi RockDad,
          Try something like below.
          As you can see I have used radio buttons, with an onClick event handler.
          So when a person clicks on a radio button the value is passed to the
          <cfwindow> and passed onto the source.cfm page.
          Hope this helps you out some.
          Leonard B
          <cfform name="newslinks">
          <cfinput name="newsID"
          type="radio"
          value="[#value_to_pass#]"
          onClick="javascript:ColdFusion.Window.show('[cfwindow_name]')"
          onMouseOver="style.cursor='pointer'"> #headline#
          type="radio"
          value="[value_to_pass#]"
          </cfform>
          <cfwindow
          title=""
          Width="500"
          Height="400"
          center="true"
          modal="true"
          source="news_detail.cfm?NewsID={newslinks:newsID}">
          </cfwindow>
          • 2. Re: Cfwindow and variable
            Adam Cameron. Level 5
            Is it just me, or is the name of your window and the name of the window you're trying to show different from one another?
            I would not have expected this sort of mismatch to cause your problem, but it certainly can't be helping.
            Adam
            • 3. Re: Cfwindow and variable
              Leonard B Level 2
              Adam - Good catch,
              I saw that last night and nothing stood out to me. You are right from what
              I am seeing with the code presented, the two do not match. Guess fresh
              eyes can make a difference.
              I would also be surprised if a variable cannot be found error is not be
              generated since when the page is loaded it would be looking for the
              #variable# that is added to the <cfwindow> name attribute and at time
              of load would not be available.
              -- Just me thinking is all and sometimes that can be dangerous - lol.
              Leonard B
              • 4. Re: Cfwindow and variable
                Leonard B Level 2
                RockDad,
                If you are simply looking to generate a pop window and dynamically
                display content in the popped up window, an alternative to the
                <cfwindow> process could be the use of javascript and do something
                like below.
                Although not as fancy as the <cfwindow> process would be an
                alternative for you to have for inclusion in your project.
                Leonard B
                = = = Code below = = =
                On the page you will be linking from insert the code below into the
                respective sections of the page.
                <head>
                      <SCRIPT LANGUAGE="JavaScript">
                     <!-- Begin
                     function NewWindow(mypage, myname, w, h, scroll) {
                     var winl = (screen.width - w) / 2;
                     var wint = (screen.height - h) / 2;
                     winprops = 'height='+h+',width='+w+',top='+wint+',left='+winl+',scrollbars='+scroll+',resizable'
                     win = window.open(mypage, myname, winprops)
                     if (parseInt(navigator.appVersion) >= 4) { win.window.focus(); }
                    //  End -->
                   </script>
                </head>
                <body>
                     <a
                     href="[destination_page].cfm?news_id=#URLEncodedFormat(news_id)#"
                     onClick="NewWindow(this.href,'name','[width]','[height]','yes');return false;">[link title/name here]</a>
                </body>
