I have the following problem. I have been using RoboHelp for HTML now for a while to generate JavaHelp projects.
Since I am generating a context-sensitive help and my customer is only able to implement a help project based on JavaHelp 1.1.3, I cannot use JavaHelp 2.0, though there is a whole series of restrictions with JavaHelp 1.1.3.
With RoboHelp v7, everything worked fine when creating a JavaHelp 1.1.3 project. With RoboHelp v8, however, the TOC is missing in the JavaHelp. It is not displayed. Usually, I am working on my main PC under Windows XP.
I tried to generate a JavaHelp 1.1.3 version with RH 8 under Vista (which I have on my notebook), and the TOC was displayed. The project source is a Web Help project.
Is this a known bug or might there be something else with the Java installation that I should consider? As far as I know, there was a similar issue with TOCs and JavaHelp 1.1.3. under RoboHelp X5 long time ago.
I appreciate any answer that might help fixing this problem.
Thanks in advance.
Best regard,
Lena
my question has already been answered in the following thread:
http://forums.adobe.com/message/1964771
I hope that it will help many others of you having the same problem.
Cheers,
Lena
