13 Replies Latest reply on May 9, 2009 6:08 AM by Gregory Lafrance
    TileList - increase distance between itemRenderer elements
    BregoXX
      sorry for my English, i`m from Belarus
      But i have a question
      How to increase distance between itemRenderer elements in TileList?
        • 1. Re: TileList - increase distance between itemRenderer elements
          Gregory Lafrance Level 6
          To increase the distance between each item in the TileList (each instance of the itemRenderer), use the horizontalGap style property (or vertical distance for other containers, use verticalGap).
          <mx:TileList horizontalGap="30"/>
          or in ActionScript
          myTL.setStyle("horizontalGap", 30);
          For individual controls WITHIN your item renderer, once again, use the horizontalGap and verticalGap for the containers in the renderer, or the paddingLeft, paddingRight, paddingTop, paddingBottom styles for individual controls in the renderer as necessary.
          If this answers your question, please mark it as such.
          • 2. Re: TileList - increase distance between itemRenderer elements
            Michael Borbor Level 4
            Verify the control's styles to see if it has paddingTop,
            paddingBottom. If it does then you can use them to do what you want.
            Sincerely,
            Michael
            • 3. Re: TileList - increase distance between itemRenderer elements
              BregoXX Level 1
              Sincerely,
              Michael
              I need to increase horizontal distance.
              or in ActionScript
              TileList don`t have such property/style as verticalGap and horizontalGap
              • 4. Re: TileList - increase distance between itemRenderer elements
                Could you post how you declare your TileList?
                Sincerely,
                Michael
                >> Sincerely,
                >> Michael
                >> or in ActionScript
                horizontalGap
                • 5. Re: TileList - increase distance between itemRenderer elements
                  Then ensure the renderer is wrapped in a container like HBox or VBox and then use paddingLeft or paddingRight.
                  • 6. Re: TileList - increase distance between itemRenderer elements
                    BregoXX Level 1
                    <mx:TileList
                    id = "documentList" height = "100%" columnCount="3"
                    minHeight="
                    40"
                    width = "
                    100%"
                    borderStyle="
                    none"
                    verticalScrollPolicy="
                    on"
                    selectable = "
                    false"
                    doubleClickEnabled = "
                    false"
                    itemClick = "showDocumentVersion(event)"
                    dataProvider = "
                    {documentVesions}"
                    itemRenderer = "
                    de.dts.isy3suite.plugin.bcspecificpage.documentlist.DocumentVersionItemRender">
                    </mx:TileList>
                    • 7. Re: TileList - increase distance between itemRenderer elements
                      We need to see the code for your renderer. If you do not have control over it, wrap it in an HBox.
                      • 8. Re: TileList - increase distance between itemRenderer elements
                        BregoXX Level 1
                        <?xml version = "1.0" encoding = "utf-8"?>
                        <mx:VBox xmlns:mx = "http://www.adobe.com/2006/mxml"
                                 borderColor="red"
                                 borderStyle="solid"
                                 width = "100"
                                 height = "200"
                                 horizontalAlign = "left"
                                 verticalGap="0"
                                 horizontalScrollPolicy = "off"
                                 verticalScrollPolicy = "off">
                            <mx:Script>
                                <![CDATA[
                        [Bindable]
                                    public var preparingFunction:PluginConfigurationFunction = FunctionManager.instance.getFunctionByName("Preparing") as PluginConfigurationFunction;
                                    public function getScale(documentVersion:DocumentVersion):Number
                                        var spread:Spread = documentVersion.spreads.getItemAt(0) as Spread;
                                        var cf:Number = getCoefficient(100, 60, spread.width, spread.height);
                                        return cf;
                                    public function getCoefficient(parentWidth:Number, parentHeight:Number, childWidth:Number, childHeight:Number):Number
                                        var k1:Number = parentWidth / childWidth;
                                        var k2:Number = parentHeight / childHeight;
                                        return (k2 < k1) ? k2 : k1;
                                    private function onCreationComplete():void
                                        preview.source = PreviewManager.getDocumentVersionPreviewUrl(data.identity, 1 /*getScale(data as DocumentVersion)*/ , preparingFunction.pluginConfigurationIdentity);
                                    private function checkBox_clickHadler(event:MouseEvent):void
                                        event.stopPropagation();
                            </mx:Script>
                         <mx:Image id = "preview"
                          width = "100%"
                          height = "100%"
                          useHandCursor = "true"
                          buttonMode = "true"
                          mouseChildren = "false"
                          creationComplete = "onCreationComplete()"/>
                            <mx:Label text = "Layout-Nr.: {data.articleNumber}"
                          styleName="bcDocumentVersionItemRendererStyle"
                          buttonMode = "true"
                          paddingLeft = "10"/>
                            <mx:CheckBox label = "Standard Layout"
                             rollOverEffect="null"
                                paddingLeft = "10"
                                click = "checkBox_clickHadler(event)"/>
                            <mx:Label text = "{data.masterDocument.name}"
                                buttonMode = "true"
                            <mx:Label text = "{data.masterDocument.description}"
                          fontWeight="normal"
                               buttonMode = "true"
                        </mx:VBox>
                        i attach image
                        From above is old project on JavaScript
                        From below is new project on Flex
                        And i must to do view similar.
                        • 10. Re: TileList - increase distance between itemRenderer elements
                          BregoXX Level 1
                          It is necessary to be engaged in language studying, because that does not suffice knowledge for high-grade dialogue.
                          In each row i have 3 itemRender
                          First itemRender is placed correctly, but second not correctly and third more uncorrectly then second in comparison with the old project.
                          And if i use paddingLeft in itemRenderer so wrong would be placed first itemRenderer
                          • 11. Re: TileList - increase distance between itemRenderer elements
                            I'm not understanding what you are trying to say. What is wrong with the second, what is wrong with the third? Need a more detailed description of what is wrong, using terms we all can clearly understand, like x pixels to the right, x pixels too far to the right, etc. Maybe upload screen shots.
                            Also, maybe post simplified yet 'complete' code that exhibits the problem.
                            • 12. Re: TileList - increase distance between itemRenderer elements
                              BregoXX Level 1
                              I attach screen shot in 8 message
                              • 13. Re: TileList - increase distance between itemRenderer elements
                                What do you desire that is different from the samples in this code:
                                ---------------------- data.xml --------------------------
                                <photos>
                                    <photo>
                                        <image>images/black30_30.JPG</image>
                                        <caption>Black Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/blue30_30.JPG</image>
                                        <caption>Blue Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/brown30_30.JPG</image>
                                        <caption>Brown Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/gray30_30.JPG</image>
                                        <caption>Gray Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/green30_30.JPG</image>
                                        <caption>Green Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/Olive30_30.JPG</image>
                                        <caption>olive Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/red30_30.JPG</image>
                                        <caption>Red Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/teal30_30.JPG</image>
                                        <caption>Teal Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/white30_30.JPG</image>
                                        <caption>White Square</caption>
                                    </photo>
                                    <photo>
                                        <image>images/yellow30_30.JPG</image>
                                        <caption>Yellow Square</caption>
                                    </photo>
                                </photos>
                                -------------- MainApp.mxml ------------------------
                                <?xml version="1.0"?>
                                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                                  creationComplete="photosRequest.send();">
                                  <mx:Script>
                                    <![CDATA[
                                      import mx.rpc.events.ResultEvent;
                                      import mx.collections.XMLListCollection;
                                      [Bindable] private var xlc:XMLListCollection;
                                      private function photosHandler(evt:ResultEvent):void{
                                        xlc = new XMLListCollection(evt.result..photo);
                                  </mx:Script>
                                  <mx:HTTPService id="photosRequest" url="data.xml" result="photosHandler(event)"
                                    resultFormat="e4x"/>
                                  <mx:HBox width="100%">
                                    <mx:TileList dataProvider="{xlc}" rowHeight="100"
                                      columnWidth="100">
                                      <mx:itemRenderer>
                                        <mx:Component>
                                          <mx:VBox horizontalAlign="center" verticalAlign="middle"
                                            backgroundColor="0xCC4455" borderStyle="solid"
                                            borderThickness="2">
                                            <mx:Image source="{data.image}"/>
                                            <mx:Text text="{data.caption}"/>
                                          </mx:VBox>
                                        </mx:Component>
                                      </mx:itemRenderer>
                                    </mx:TileList>
                                      columnWidth="130">
                                      <mx:itemRenderer>
                                        <mx:Component>
                                            borderThickness="2" paddingLeft="20" paddingRight="20">
                                          </mx:VBox>
                                        </mx:Component>
                                      </mx:itemRenderer>
                                    </mx:TileList>
                                  </mx:HBox>
                                      columnWidth="150">
                                      <mx:itemRenderer>
                                        <mx:Component>
                                            borderThickness="2" paddingLeft="30" paddingRight="30">
                                          </mx:VBox>
                                        </mx:Component>
                                      </mx:itemRenderer>
                                    </mx:TileList>
                                      columnWidth="170">
                                      <mx:itemRenderer>
                                        <mx:Component>
                                            borderThickness="2" paddingLeft="40" paddingRight="40">
                                          </mx:VBox>
                                        </mx:Component>
                                      </mx:itemRenderer>
                                    </mx:TileList>
                                  </mx:HBox>
                                </mx:Application>
