8 Replies Latest reply on May 9, 2009 8:34 AM by 3rdshiftcoder
    webservices - formatting xml
    3rdshiftcoder
      hi-
      below is my code sample. i can return a response from webservice to my text field but i cant filter out the parts i dont need.
      this is what it returns. as you will see with my code below i cant filter what i need.
      thanks for any assistance on how i can filter that data.
      3rdshiftcoder
      <GetWeatherByZipCodeResponse xmlns="http://www.webservicex.net" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
        <GetWeatherByZipCodeResult>
          <Latitude>33.3291245</Latitude>
          <Longitude>111.9943</Longitude>
          <AllocationFactor>0.008745</AllocationFactor>
          <FipsCode>04</FipsCode>
          <PlaceName>PHOENIX</PlaceName>
          <StateCode>AZ</StateCode>
          <Details>
            <WeatherData>
              <Day>Saturday, May 09, 2009</Day>
              <WeatherImage>http://forecast.weather.gov/images/wtf/few.jpg</WeatherImage>
              <MaxTemperatureF>103</MaxTemperatureF>
              <MinTemperatureF>70</MinTemperatureF>
              <MaxTemperatureC>39</MaxTemperatureC>
              <MinTemperatureC>21</MinTemperatureC>
            </WeatherData>
            <WeatherData>
              <Day>Sunday, May 10, 2009</Day>
              <MaxTemperatureF>101</MaxTemperatureF>
              <MinTemperatureF>67</MinTemperatureF>
              <MaxTemperatureC>38</MaxTemperatureC>
              <MinTemperatureC>19</MinTemperatureC>
            </WeatherData>
      etc...
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns="*" layout="absolute"
      creationComplete="userRequest.GetWeatherByZipCode()">
      <mx:WebService id="userRequest"
              wsdl="http://www.webservicex.net/WeatherForecast.asmx?wsdl"
              useProxy="false">
              <mx:operation name="GetWeatherByZipCode" resultFormat="e4x"
              fault="mx.controls.Alert.show(event.fault.faultString)"
              result="remotingCFCHandler(event)">
                  <mx:request>
                      <ZipCode>85044</ZipCode>
                  </mx:request>
              </mx:operation>
          </mx:WebService>
      <mx:Form x="22" y="10" width="493">
      <mx:HBox>
      <mx:Label text="zipcode"/>
      <mx:TextInput id="zipcode" width="300" height="500" />
      </mx:HBox>
      <mx:Button label="Submit" click="clickHandler()"/>
      </mx:Form>
      <!--<mx:DataGrid id="dgUserRequest" x="22" y="128">
      <mx:columns>
      <mx:DataGridColumn headerText="zipcode" dataField="zipcode1"/>
      <mx:DataGridColumn headerText="User Name" dataField="USERNAME"/>
      </mx:columns>
      </mx:DataGrid>-->
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.ResultEvent;
      [Bindable] public var xmlResults:XML;
      [Bindable] public var a:XMLList;
      private function remotingCFCHandler(e:ResultEvent):void
      //dgUserRequest.dataProvider = e.result;
      zipcode.text = e.result.toString();  // returns document response found above
      xmlResults= new XML(zipcode.text);
      xmlResults.ignoreWhite = true;
      var listResults:XMLList;
      // listResults = xmlResults.GetWeatherByZipCodeResponse.GetWeatherByZipCodeResult.Details.WeatherData.Day;
      // zipcode.text = "{ 'a': + listResults}";
      //    ???? the above 2 commented lines dont filter my results. i thought those 2 lines would work.
      private function clickHandler():void
         userRequest.GetWeatherByZipCode();
      </mx:Script>
      </mx:Application>
        • 1. Re: webservices - formatting xml
          Gregory Lafrance Level 6
          Have you confirmed you are getting data back? What exactly do you want to see after you filter? Your code indicates you want to see the day, but you are putting it in a variable called zipcode.
          • 2. Re: webservices - formatting xml
            3rdshiftcoder Level 1
            hi -
            zipcode is the id for the textinput control.
            this line above returns data from the response but it is the entire data and not filtered.
            //xmlResults.ignoreWhite = true;
            here i am trying to add the data returned in the text control to an xml variable.
            and this is where i get lost totally. i thought that this would filter my data and place the filtered data
            into the textinput control with id of zipcode.
            thanks for replying-
            3rdshiftcoder
            • 3. Re: webservices - formatting xml
              But what do you mean when you say you are trying to filter, and what are you trying to see from your data. Are you trying to see data for certain dates?
              <WeatherData>
                    </WeatherData>
              • 4. Re: webservices - formatting xml
                Hi Greg-
                Exactly! except i dont really care about dates. i am more interested in the temperatures.
                I just used that as an example.
                Here is the link that explains about filtering e4x.
                http://dispatchevent.org/roger/as3-e4x-rundown/
                below is a quote from this link and it describes an expression with filters.
                " These are the basics of E4X. You’ve probably figured these ones out already cuz you is a pimp!
                thePeople.person.age
                Use dot syntax to select child nodes by name. The variable is already associated with the root node so there’s no need to write <people> into the expression. The expression above has two successive filters. The first one gets you all the <person> nodes  immediately below the root node, in other words, an XMLList. The second one gets you all the <age> nodes below all the nodes in the first filter. Result:
                <age>27</age>
                <age>26</age>
                Again, this is an XMLList, and notice how it retrieves all the age nodes under all the person nodes.
                i want to access WeatherData and retrieve the temperature values.
                a node <MaxTemperatureF>103</MaxTemperatureF> is one i may wish to get the value of.
                the value for this node i'd like to return is 103.
                • 5. Re: webservices - formatting xml
                  i cant figure out when i leave these lines commented out i can get data.
                  but when i apply the filter, i get
                  verbatim
                  now if i was to comment the following 3 lines this is what the data looks like
                  in the textinput control.
                  //var listResults:XMLList;
                  //listResults = xmlResults.GetWeatherByZipCodeResult.Details.WeatherData.MaxTemperatureF;
                  //zipcode.text = listResults;
                  data returned to textinput control with 3 lines commented out is below:
                      <Details>
                        <WeatherData>
                        </WeatherData>
                        <WeatherData>
                        </WeatherData>
                        <WeatherData>
                          <Day>Monday, May 11, 2009</Day>
                          <MaxTemperatureF>102</MaxTemperatureF>
                          <MinTemperatureF>68</MinTemperatureF>
                          <MinTemperatureC>20</MinTemperatureC>
                        </WeatherData>
                        <WeatherData>
                          <Day>Tuesday, May 12, 2009</Day>
                          <MinTemperatureF>69</MinTemperatureF>
                        </WeatherData>
                        <WeatherData>
                          <Day>Wednesday, May 13, 2009</Day>
                          <MaxTemperatureF>100</MaxTemperatureF>
                        </WeatherData>
                        <WeatherData>
                          <Day>Thursday, May 14, 2009</Day>
                        </WeatherData>
                        <WeatherData>
                          <Day>Friday, May 15, 2009</Day>
                        </WeatherData>
                      </Details>
                    </GetWeatherByZipCodeResult>
                  </GetWeatherByZipCodeResponse>
                  • 6. Re: webservices - formatting xml
                    listResults = thePeople.person.age;
                    textfield values:
                    <age>27</age>
                    <age>26</age>
                    • 7. Re: webservices - formatting xml
                      my last post just went crazy on me.
                      dont try to understand it.  sorry.
                      This code sample works and the other code didnt. Invalid xml object?
                      I am loopy enough without this going on.
                      var thePeople:XML = <people>
                          <person name="Mims Wright" suffix="III">
                              <age>27</age>
                              <aka>Mims H Wright</aka>
                              <aka>Teh AWesoeomes!</aka>
                          </person>
                          <person name="Roger Braunstein">
                              <age>26</age>
                              <aka>Rog</aka>
                              <aka>That guy</aka>
                          </person>
                      </people>;
                      trace(thePeople.person.age);
                      results printed:
                      <age>27</age>
                      <age>26</age>
                      • 8. Re: webservices - formatting xml
                        hi-
                        i can fix this now. i will have to delete that lattitude, longitude etc. data at the top
                        of my textinput control to make it a valid xml object so i can filter.
                        i can use mystr (a String object) and clean it up with some methods.
                        this was very easy compared to my last attempt at doing this some
                        time ago with php.
                        thanks for answering.
                        3rdshiftcoder
