2 Replies Latest reply on May 9, 2009 9:54 AM by Michael Borbor
    Getting started with flex and Eclipse 3.1?
    saxisa
      Hi all,
      Im a java Eclipse RCP developer and I wanted to work on some small apps using flex.
      I have been searching around on the web for instructions on how to get everything set up, but most of them seem to skip a  few steps.
      I am using Eclipse ganymede (3.1), and have downloaded the flex sdk.  Is there a plugin or something for flex that creates the proper perspectives in eclipse?  Or what exactly do I need to do?
      Also, I see that flex uses mxml, if I want to use flex and java as opposed to flex and php or coldfusion (the only examples I saw) is that possible?  I guess Im slightly confused as to what exactly I am writing this app in... java?  Actionscript?  Php? ??
      Basically my goal is this:
      Use eclipse 3.1 (not flex builder)
      Write an RIA that can also use AIR
      Connect to a MySQL database on the backend
      I have very little experience (or need) for J2EE, but maybe I should use it?
      Can anyone point me to a good tutorial that will get me going to achieve my goal?  Or tell me what exactly I need to install, and how to put it together?
      Thank you!
