8 Replies Latest reply on May 9, 2009 5:45 PM by Michael Borbor
    Item renderers re-rendering on window resize
    RS-VN
      Hi all,
      I'm having an issue with my custom item renderers. Basically I've got the following:
      MXML file one has a datagrid with three columns.
      The data provider is an ArrayCollection with 3 entries each containing 3 datafields (ie. Time, Stats and Slots). Now the slots datafield is actually a reference to an alternate ArrayCollection. So the data provider of my datagrid is an ArrayCollection, which itself contains three additional arrays in this example. The slots uses an itemRenderer with a repeater inside to go through the array of 'Slots' and display them all in a single datagrid cell.
      Here is the code around the datagrid:
      <mx:DataGrid dataProvider="{anArray}"
      variableRowHeight="true"
      selectable="false"
      sortableColumns="false"
      width="100%">
      <mx:columns>
      <mx:DataGridColumn headerText="header1"
         width="50"
         dataField="Time">
      </mx:DataGridColumn>
         dataField="Slots"
         itemRenderer="someRenderer">
      <mx:DataGridColumn headerText="T header1"
         width="150"
         dataField="Stats">
      </mx:columns>
      </mx:DataGrid>
      And here is the code for part of the itemRenderer
      <mx:Tile xmlns:mx="http://www.adobe.com/2006/mxml"
      horizontalGap="4"
      verticalGap="4"
      paddingLeft="4"
      paddingBottom="4"
      paddingRight="4"
      paddingTop="4"
      verticalScrollPolicy="off"
      horizontalScrollPolicy="off">
      <mx:Script>
      <![CDATA[
      import mx.core.UIComponent;
      import mx.containers.VBox;
      private function handleRepeater() : void
      var anItem: OtherItemMXML= new OtherItemMXML();
      var component : UIComponent = new UIComponent();
      anItem.referenceName = resRepeat.currentItem.Ref;
      anItem.value1 = resRepeat.currentItem.Value1;
      anItem.value2 = resRepeat.currentItem.Value2;
      anItem.value3 = resRepeat.currentItem.Value3;
      anItem.value4 = resRepeat.currentItem.Value4;
      component.addChild( anItem );
      component.visible = true;
      addChild( component );
      </mx:Script>
      <mx:Repeater id="resRepeat"
      dataProvider="{data.Slots}"
      repeat="handleRepeater()">
      </mx:Repeater>
      <mx:VBox width="100"
      height="74"
      backgroundColor="#FFFFFF"
      verticalGap="0"
      verticalAlign="middle"
      mouseMove="dragInit(event)">
      </mx:VBox>
      </mx:Tile>
      So the end result of all this is that, when I first run the app, all my data in my SLOTS arrays are doubled.... meaning they all appear twice on the screen (ie. I've got one slots array with 3 items in it, well it shows up with 6 on screen).
      Second issue is that whenever I resize the screen (ie. Restore/Maximise), a new set of items get added to the grid, but this time, not doubled. So if I restore and maximize my screen, I end up with 4 times the initial number of items in my ArrayCollection...
      Any ideas why this might be happening?
      If you need more details let me know.
      Thanks!
      Marc
