8 Replies Latest reply on May 9, 2009 5:26 PM by 3rdshiftcoder
    webservices - filtering xml to get at data
    3rdshiftcoder
      hi-
      i posted earlier. my question may have been confusing to read or follow.
      here is what i ended up with.
      This code retrieves weather data - 5 day forecast for a given zip code.
      I was able to get at the data and print it out.
      I think it works now. I have to add on more features.
      I dont know how this could be accomplished simpler. I didnt think i'd have to resort to
      regExp code but i could think of no other way.
      This was a lot less work than the last time i tried it using php code. Flex and Actionscript 3
      made this easier for me.
      Thanks for helping,
      3rdshiftcoder
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns="*" layout="absolute">
      <!--creationComplete="userRequest.GetWeatherByZipCode()"-->
      <mx:WebService id="userRequest"
              wsdl="http://www.webservicex.net/WeatherForecast.asmx?wsdl"
              useProxy="false">
              <mx:operation name="GetWeatherByZipCode" resultFormat="e4x"
              fault="mx.controls.Alert.show(event.fault.faultString)"
              result="remotingCFCHandler(event)">
                  <mx:request>
                      <ZipCode>85044</ZipCode>
                  </mx:request>
              </mx:operation>
          </mx:WebService>
      <mx:Form x="22" y="10" width="493">
      <mx:HBox>
      <mx:Label text="zipcode"/>
      <mx:TextInput id="zipcode" width="300" height="500" />
      </mx:HBox>
      <mx:Button label="Submit" click="clickHandler()"/>
      </mx:Form>
      <mx:Script>
      <![CDATA[
      import flash.accessibility.AccessibilityImplementation;
      import mx.rpc.events.ResultEvent;
      private function remotingCFCHandler(e:ResultEvent):void
      var mystr:String = e.result.toString();
      //use regexp pattern match on string to get at the nodes i want.
      var pattern:RegExp = /<MaxTemperatureF>(\d+)<\/MaxTemperatureF>/g;
      var myarr:Array = mystr.match(pattern);
      var superStr:String = '';
      var i:int;
      for (i = 0; i < 5; i++)
          superStr = superStr + '   ' + myarr.pop() + "\n";
      // put it reassemble back in xml format to get the xml object i wanted in the first place
      superStr = "<MaxTemp>" +"\n" + superStr  +"</MaxTemp>";
      //zipcode.text = superStr;
      // now i create a xmllist by filtering the xml object
      var x1:XML;
      var x2:XMLList;
      x1 = new XML(superStr);
      x1.ignoreWhite = true;
      x2 = x1..MaxTemperatureF;
      zipcode.text = "Phoenix, AZ 5 day forecast" + "\n" +
      "max temperatures" + "\n" + x2.text().toXMLString();
      // finally i selected out the node data
      private function clickHandler():void
         userRequest.GetWeatherByZipCode();
      </mx:Script>
      </mx:Application>
        • 1. Re: webservices - filtering xml to get at data
          Michael Borbor Level 4
          Could I suggest you to edit your post and put your code inside the Syntax Highlighting - Java so It'll be easier to read.
          • 2. Re: webservices - filtering xml to get at data
            3rdshiftcoder Level 1
            Hi Michael-
            I hope this is better. i indented with the space bar. I am using FlashDevelop and not a Java ide.
            thanks for the tip.
            3rdshiftcoder
            <?xml version= "1.0" encoding= "utf-8"?>
            <mx:Application xmlns:mx= "http://www.adobe.com/2006/mxml" xmlns= "*" layout= "absolute">
                <mx:WebService id= "userRequest"
                    useProxy="false">
                    <mx:operation name= "GetWeatherByZipCode" resultFormat= "e4x"
                        fault= "mx.controls.Alert.show(event.fault.faultString)"
                        result= "remotingCFCHandler(event)">
                        <mx:request>
                        </mx:request>
                    </mx:operation>
                </mx:WebService>
            <mx:Form x= "22" y= "10" width= "493">
                <mx:HBox>
                    <mx:Label text= "zipcode"/>
                        <mx:TextInput id= "zipcode" width= "300" height= "500" />
                </mx:HBox>
                <mx:Button label= "Submit" click= "clickHandler()"/>
            </mx:Form>
            <mx:Script>
                <![CDATA[
                private function remotingCFCHandler(e:ResultEvent):void {
                    var i:int;
                    for (i = 0; i < 5; i++){
                    var x1:XML;
                    var x2:XMLList;
                    // finally i selected out the node numeric values
                    private function clickHandler():void {
            </mx:Script>
            </mx:Application>
            • 3. Re: webservices - filtering xml to get at data
              Well what I meant is that you before posting the code in the forum "post editor" there is this icon >> you click on it and you'll find The Syntax Highlighting-Java.
              This is the result of that.
              Could you post the XML file, and tell me what is your problem fellow developer?
              • 4. Re: webservices - filtering xml to get at data
                I see you're using RegEx to construct an XML object. Post the XML please
                • 5. Re: webservices - filtering xml to get at data
                          useProxy="false">
                              <mx:request>
                              </mx:request>
                          </mx:operation>
                      </mx:WebService>
                      <mx:HBox>
                      </mx:HBox>
                  </mx:Form>
                  <mx:Script>
                      <![CDATA[
                          var i:int;
                          var x1:XML;
                          var x2:XMLList;
                  </mx:Script>
                  </mx:Application>
                        Hi- Michael.
                               There is no problem anymore ( i hope ). I was just trying to share some code i fixed that was a problem this morning
                               in an earlier post.
                               Thanks for the tip on the indenting. I see i can use xml indent too. very cool.
                               have a good weekend,
                                       jim
                  • 6. Re: webservices - filtering xml to get at data
                    You're welcome, have a good weekend too. Please don't forget to close the thread.
                    • 7. Re: webservices - filtering xml to get at data
                      <GetWeatherByZipCodeResponse xmlns="http://www.webservicex.net" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
                        <GetWeatherByZipCodeResult>
                          <Latitude>33.3291245</Latitude>
                          <Longitude>111.9943</Longitude>
                          <AllocationFactor>0.008745</AllocationFactor>
                          <FipsCode>04</FipsCode>
                          <PlaceName>PHOENIX</PlaceName>
                          <StateCode>AZ</StateCode>
                          <Details>
                            <WeatherData>
                              <Day>Saturday, May 09, 2009</Day>
                              <WeatherImage>http://forecast.weather.gov/images/wtf/nskc.jpg</WeatherImage>
                              <MaxTemperatureF>102</MaxTemperatureF>
                              <MinTemperatureF>67</MinTemperatureF>
                              <MaxTemperatureC>39</MaxTemperatureC>
                              <MinTemperatureC>19</MinTemperatureC>
                            </WeatherData>
                            <WeatherData>
                              <Day>Sunday, May 10, 2009</Day>
                              <WeatherImage>http://forecast.weather.gov/images/wtf/skc.jpg</WeatherImage>
                            </WeatherData>
                            <WeatherData>
                              <Day>Monday, May 11, 2009</Day>
                              <WeatherImage>http://forecast.weather.gov/images/wtf/few.jpg</WeatherImage>
                            </WeatherData>
                            <WeatherData>
                              <Day>Tuesday, May 12, 2009</Day>
                              <MaxTemperatureF>101</MaxTemperatureF>
                              <MinTemperatureF>68</MinTemperatureF>
                              <MaxTemperatureC>38</MaxTemperatureC>
                              <MinTemperatureC>20</MinTemperatureC>
                            </WeatherData>
                            <WeatherData>
                              <Day>Wednesday, May 13, 2009</Day>
                              <MaxTemperatureF>103</MaxTemperatureF>
                            </WeatherData>
                            <WeatherData>
                              <Day>Thursday, May 14, 2009</Day>
                              <MaxTemperatureF>104</MaxTemperatureF>
                              <MaxTemperatureC>40</MaxTemperatureC>
                            </WeatherData>
                            <WeatherData>
                              <Day>Friday, May 15, 2009</Day>
                              <MinTemperatureF>69</MinTemperatureF>
                              <MinTemperatureC>21</MinTemperatureC>
                            </WeatherData>
                          </Details>
                        </GetWeatherByZipCodeResult>
                      </GetWeatherByZipCodeResponse>
                       Hi Michael -
                           I just realized that my data was in reverse.
                           After the following line
                               //add this line to reverse the array:
                              myarr = myarr.reverse();
                           And if you want all 7 days...sorry thought it was 5 just increase the loop max.
                                thanks,
                                   enjoy the weekend
                      • 8. Re: webservices - filtering xml to get at data
                        post with associated threads now closed....
