10 Replies Latest reply on Nov 4, 2009 6:50 AM by Patrick Leckey
    Highlighting text in C#
    bp54321
      I started the JSObjectControl.cs example thats downloaded with the SDK 9 as a base.  I've modified it to add a watermark to each page. (That works).  I am able to search thru the words on each page and find a match on a string. (That also works).  What I want to do is Highlight those matches and then save the document.  (I can successfully do the save).  What I haven't figured out is how to highlight.  I've searched the forums and web and while I can find many examples in VB, nothing using the InvokeMethod used in the C# example.  I've tried all kinds of parms passed into "addAnnot" method but all that is ever returned from the call is a null object, and of course no highlighting on the page.  Below is the code up to the point where I found a match and want to highlight the word.  The getPagenthwordquads returns a quad of valid numbers so all looks good until then.  Can anyone help me with the required code to finish this off.
        for (int i = 0; i < nPages; i++)
                          // check each word in a page
                          object[] getPageNumWordsParam = { i };
                          double nWords = (double)T.InvokeMember(
                              "getPageNumWords",
                              BindingFlags.InvokeMethod |
                              BindingFlags.Public |
                              BindingFlags.Instance,
                              null, jsObj, getPageNumWordsParam);
                          for (int j = 0; j < nWords; j++)
                              //get a word
                              object[] getPageNthWordParam = { i, j };
                              String word = (String)T.InvokeMember(
                                  "getPageNthWord",
                                  null, jsObj, getPageNthWordParam);
                              // compare the word with what the user wants
                              int result = String.Compare(word, "Word to match");
                              // if same
                              if (result == 0)
                                  //nCount = nCount + 1;
                                  object[] quads = (object[])T.InvokeMember(
                                      "getPageNthWordQuads",
      ********************** Help needed here to Highlight the found word. *************************************************
