1 Reply Latest reply on May 10, 2009 4:42 AM by Mylenium
    Problems in exporting
    ayalovejun
      I am new to After Effects, so hope some could help me as I can't find any solution on the Internet.
      When I try to export my video by using the 'make movie' function,
      I can export a .avi by choosing 'lossless' in the output module
      but when I try to do so but choosing other templates like 'Microsoft DV NTSC 32k'
      it doesn't wort and pop up the following message
      There is also another problem
      When I export the file to .avi by choosing 'File' > 'Export'
      There is no option when I want to choose a compressor in sound option
      I really need someone to help out
      Thanks~
        • 1. Re: Problems in exporting
          Please read the online help on Rendering and Exporting. You need to addyour composition to the render queue and adjust the output module settings to gain access to more and different rendering options. Or for creating your own output module templates, use the Edit --> Templates --> Output Module... menu. The error tells you, that you are trying to use DV compression on a comp, that is not the proper size. DV always must be 720x480 for NTSC or 720x576 for PAL
          Mylenium
