6 Replies Latest reply on May 10, 2009 7:14 PM by Levsky
    javascript use ..
      Here is the issue.I decided to use JavaScript to create popup window and I need to help again
      here is a scrip i use for pop up form assigned to a button
      btn_txt.onRelease = function() {
      getURL ("javascript:NewWindow=window.open( ../pages/lev_att.htm , txtWin  , width=600,height=800,left=20,top=40,toolbar=No,location=No,scrollbars=No,status=No,resiza ble=No,fullscreen=No );NewWindow.focus(); void(0);");
      it do not gave me errors but it do not work.
      Have any one have idea why?
      or any suggestions...
      Thanx in advance
        • 1. Re: javascript use ..
          Compare your code to the following example taken from a Google search (http://www.flash-db.com/PopUp/JavaScriptPopUp.php?page=2).  The first thing I notice is you are not quoting (single quotes) some things:
          getURL ("javascript:NewWindow=window.open('ShowPopup.php','newWin','width=400,height=300,left=0,top=0,
          toolbar=No,location=No,scrollbars=No,status=No,resizable=No,fullscreen=No');  NewWindow.focus();
          • 2. Re: javascript use ..
            Levsky Level 1
            I can see what r u talking about and i had made canges however, i can not get it to work
            here how it is looking now:
            getURL ("javascript:NewWindow=window.open( '../pages/lev_att.htm' , 'txtWin'  ,'width=600,height=800,left=20,top=40,toolbar=No,location=No,scrollbars=No,status=No,resi zable=No,fullscreen=No' );NewWindow.focus(); void(0);'");
            I still can here a click but form is not poping up.
            If i would use just actionscript  and do this way
            it is ok but it openning up ful window and I need to have a pop up 600 X 800 so I am lost.
            I to google and went through several scripts...
            • 3. Re: javascript use ..
              robdillon Most Valuable Participant
              At the end of your getURL function, you have a single quote and a double quote, make it just a double quote. You may have a problem with the path to your new html file, put in the full url to be sure that the path is not the problem.
              If you are using a browser that has reporting capabilities, like Firefox, open the Error Console to see if there are any errors reported when this getURL call is made.
              • 4. Re: javascript use ..
                Levsky Level 1
                I was a greate idea ( why did i think of it)
                Code was SLYPPY writen spaces etc
                I run on firefox and it gave me all ther errors I just missed...
                I have fixe the errors and it is OK
                Tahnk you all for your imput
                U see a little  from every one and problem is resolved
                • 5. Re: javascript use ..
                  It's good to hear that you got it working.
                  • 6. Re: javascript use ..
                    Levsky Level 1
                    Thank you Ned
                    I an presistant one
                    I will search until get the good results
                    I build my business on this proncpal
                    And I belive on making good friends on the way
                    My father REST his SOL use to say u don need $1000 just 10 friesnds
                    THey r more important maney alway can be made..
