5 Replies Latest reply on May 12, 2009 5:49 PM by schelling
    I have DW CS4 - do I also need Contribute CS4?
    charlieapple Level 1
      I have built a site in Dreamweaver CS4.  The owner wants to edit it and is buying Contribute CS4.  Do I need to also own Contribute CS4 to be able to administrate the site, give keys, manage templates, etc., or can I continue to do all this in Dreamweaver while he updates the site in Contribute CS4?
      Been waiting a long while for a reply to this question posted a month ago on the general discussion board.  Grateful for a response.  Thank you!!
        • 1. Re: I have DW CS4 - do I also need Contribute CS4?
          schelling Level 1
          Was just here posting a Question of my own and saw your post. I'm afraid there's no way around having to use Contribute to administer the website. However, if you think you're only going to have to do it once, you can download a trial version and get all your work done in 30 days, before the trial runs out.
          • 2. Re: I have DW CS4 - do I also need Contribute CS4?
            Thank you very much for answering my question.  Knowing the site owner as I do, I'll be doing it long after 30 days so I guess I'll have to invest in Contribute to administer the site.
            Can I ask another on the same issue?  If they have contribute and I have contribute, would I still use Dreamweaver to make proper site changes to templates, etc., or would I stop using Dreamweaver and ONLY use Contribute?
            Many thanks
            • 3. Re: I have DW CS4 - do I also need Contribute CS4?
              schelling Level 1
              You can keep using Dreamweaver. If you prefer some of the features of
              Contribute for quick page fix-ups — or you want to share drafts with
              others before posting — you can use that on small jobs, but I find
              that I'm just too comfortable with DW to leave it's editing
              environment for the more specific workflow of Contribute.  I end up
              using Dreamweaver for just about everything, although I occasionally
              use Contribute, just so I get a sense of what the client's workflow is
              like or to offer technical support to the users.
              • 4. Re: I have DW CS4 - do I also need Contribute CS4?
                Thanks Gary.  So does that mean I continue to make changes in Dreamweaver and "put" the files as normal.  They then use Contribute and when they make changes then to the site, do I just have to use the 'synchronise' feature or 'get' feature to make sure I'm looking at the most recent pages in my Dreamweaver and not overwriting pages they've already edited?  And when they create a new page in Contribute, how do I make sure it's saved keeping the file structure that I have set?  As I have never used Contribute before, would you recommend that I try it as if I am the client to see what happens and how it works from their side?  Is it the exact same product that they get that I get and you just say at the set up whether you are the controller/designer or end user, or are we both treated exactly the same as far as Contribute is concerned?  Can I use my own copy of Contribute for other clients (ie. more than one site) to manage in the same way?
                Sorry to have so many questions!!  I'm sure I'm not done yet!!
                Thank you for your continued patience
                • 5. Re: I have DW CS4 - do I also need Contribute CS4?
                  schelling Level 1
                  Let me try to address your questions and give you a sense of the
                  First off, when you configure a site to use Contribute there are three
                  key decisions:
                  1) How and if you're going to let your clients create new pages (as
                  opposed to just letting them edit ones YOU create)
                  2) Templates: How many and how complex are the they going to be? (With
                  that in mind, if you haven't messed around with templates yet, time to
                  start working with them, they're key to keeping people from messing up
                  your design, since you can enable areas within tags, leaving the tags
                  — and classes and ids — untouched and untouchable.)
                  3) How many users and what are their roles? (Administrator, Publisher,
                  Writer). Briefly, Administrators control the users and have access to
                  everything (you can have more than one). Writers can edit pages, but
                  have to send them to someone else to publish. Publishers can edit and
                  The simplest solution is to just create the pages yourself, mark off
                  content areas within your div tags as editable and let them edit
                  within those. You can even limit access to CSS rules, allowing only a
                  small set that keeps your clients from using chartreuse headers on
                  magenta backgrounds.
                  As far as your workflow goes, when you enable a site for Contribute,
                  the site automatically goes into Check In/Out mode. A page can be
                  checked out by only one person at a time, regardless of whether
                  they're using Contribute or Dreamweaver. On your part, you'll just
                  have to remember to check in your file when you're done editing
                  (rather than just "Put"). If you do that, you won't have to
                  synchronize, since you'll always be checking out the page on the site,
                  rather than working on a local copy.  (Having said that, periodically
                  I do synchronize my local copy of the site, so that I can make a full
                  site backup to DVD. With the economy the way it is, there's no telling
                  when your web host might just go belly up, leaving your client's
                  content somewhere on a hard drive and you with no way of getting it.)
                  I think for your own peace of mind, you'll want to set up a test page
                  early in the design process and really think about what you're going
                  to let your client touch by editing it a few times in Contribute
                  yourself, getting an idea of how much control you want the user to
                  have, getting a feel for the whole synchronizing templates, making a
                  back up copy, saving a draft and publish workflow that is Contribute.
                  My answers seem to grow exponentially with each of your questions. At
                  this rate I'll be writing a manual!
