3 Replies Latest reply on May 11, 2009 5:32 AM by ice9_us
    filter on strings
    ice9_us Level 1
      public
      var result:XMLList = new XMLList;
      /// hd_ticketKey hd_ticketNumber
      result = item.(@hd_ticketNumber == hdsearch.text || @hd_ticketKey == hdsearch.text);
      if ( result.length() > 0 ) {
      return true;
      else {
      return false;
      hd_number will == Disk issue or disk_issue...
      When i enter the info for my search i may type   disk and want the search to hit on both..
      how do i do that where you see
      result = item.(@hd_ticketNumber == hdsearch.text...
      can i even do it? I am not able to find any info on this.
      function filterhddata(item:XML):Boolean {
        • 1. Re: filter on strings
          ice9_us Level 1
          this cut out lots of stuff in my function..
          public
          return true;
          else {
          return false;
          • 2. Re: filter on strings
            ntsiii Level 3
            Sorry, I am not following your question.  What is not working?
            Tracy
            • 3. Re: filter on strings
              ice9_us Level 1
              here ya go..
              i want to get a hit on any combo of keys i type..
              if it is in either col..
              so if i type disk or Disk it will come up with any thing that has the work "disk" in it.. same thing with the numebrs..
              2 brings up everything with a 2
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
              <mx:Script>
                   <![CDATA[
                        import mx.messaging.channels.StreamingAMFChannel;
                        import mx.messaging.AbstractConsumer;
                        import mx.events.ListEvent;
                        import mx.collections.ArrayCollection;
                        import mx.collections.XMLListCollection;
                        import mx.states.SetProperty;
                        import mx.events.ItemClickEvent;
                        import mx.managers.SystemManager;
                        import mx.rpc.events.ResultEvent;
                        import mx.rpc.events.FaultEvent;
                        import mx.core.Application;
                        import mx.controls.Alert;
              public function init():void {
                   get_ticketList2.send();
                   public function filterhddata(item:XML):Boolean {
                   var result3:XMLList = new XMLList;
                   //var result:Number = new Number;
                   //var result2:Number = new Number;
                   //var s:String = new String;
                   result3 = item.(@hd_ticketNumber == hdsearch.text || @hd_ticketKey == hdsearch.text);
                   //s = item.@hd_ticketNumber.toString();
                   //result = s.indexOf(hdsearch.text);
                   if ( result3.length() > 0 ) {
                   //if ( result3.length > 0 || result > 0   ) {
                        return true;
                   } else {
                        return false;
              public function filterdata():void {
                   if ( hdsearch.text != "" ) {
                        ticketListCol.filterFunction = filterhddata;
                   } else {
                        ticketListCol.filterFunction = null;
                   ticketListCol.refresh();
              public var ticketList:XMLList = new XMLList;
              public var ticketListCol:XMLListCollection = new XMLListCollection;
              public function relatePR():void {
                   //modifyrelation.send();
              public function get_ticketList(event:ResultEvent):void {
                   ticketList=event.result.GetTicketData;
                   ticketListCol.source = ticketList;
              public function faultHandler(event:FaultEvent):void {
                        Alert.show(event.fault.faultString, event.fault.faultCode);
              </mx:Script>
              <mx:HTTPService id="get_ticketList2" url="http://softnetinc.net/cgi-bin/get_ticketList.cgi" method="GET" result="get_ticketList(event)"
                   fault="faultHandler(event)" resultFormat="e4x" />
                   <mx:AdvancedDataGrid x="201.5" y="220" id="ticketListDisplay" designViewDataType="flat" height="148" dataProvider="" width="386" >
                        <mx:columns>
                             <mx:AdvancedDataGridColumn headerText="PR_Number" dataField="@hd_ticketKey" width="70"/>
                             <mx:AdvancedDataGridColumn headerText="PR_Name" dataField="@hd_ticketNumber" width="200"/>
                        </mx:columns>
                   </mx:AdvancedDataGrid>
                   <mx:TextInput id="hdsearch" x="33.5" y="220" enter="filterdata()"/>
              </mx:Application
