8 Replies Latest reply on May 17, 2009 2:19 AM by thesteelmam
    datagrid problem
    thesteelmam Level 1
      hi all
      how r u
      i have a small problem in datagrid and hope any one help me
      i created a datagrid that each row can has its own color i used this code
      package Models
            import flash.display.Sprite;
            import mx.collections.ArrayCollection;
            import mx.controls.DataGrid;
           public class myDataGrid extends DataGrid
               private var _coloredRowIndex:int;
               private var _rowColorCode:uint;
               private var _setColorRowIndex:Boolean;
               public function set setColorRowIndex(b:Boolean):void
                   _setColorRowIndex = b;
               public function get setColorRowIndex():Boolean
                   return _setColorRowIndex;
               public function set coloredRowIndex(i:int):void
                   _coloredRowIndex = i;
               public function get coloredRowIndex():int
                   return _coloredRowIndex;
               public function set rowColorCode(colorValue:uint):void
                   _rowColorCode = colorValue;
               public function get rowColorCode():uint
                   return _rowColorCode;
               override protected function drawRowBackground(s:Sprite,rowIndex:int,y:Number,height:Number,color:uint,dataIndex:int):void
                  try{
                            if(setColorRowIndex == true)
                       if(rowIndex == coloredRowIndex)
                           color = rowColorCode;
                           super.drawRowBackground(s,rowIndex,y,height,color,dataIndex);
                       else
                   else
                       if((dataProvider as ArrayCollection).getItemAt(rowIndex,0).status==0)
                           color = 0xffffff;
                       else if((dataProvider as ArrayCollection).getItemAt(rowIndex,0).status==1)
                           color = 0xdf8b41;
                       else if((dataProvider as ArrayCollection).getItemAt(rowIndex,0).status==2)
                           color = 0xa9a79f;
                           else if((dataProvider as ArrayCollection).getItemAt(rowIndex,0).status==3)
                           color = 0x00ff00;
                       else
                  catch(err:Error){
      it works very good but the problem is :
      when i scroll the datagrid vertically the rows don't update its color, i mean the the rows scrolled but the colors don't
      any help?
      thanx alot
        • 1. Re: datagrid problem
          Barna Biro Level 3
          Hi there,
          Try to invalidate the display or the properties of the dataGrid. You need to do this to force revalidation so that it will update it's properties whenever you scroll it. Read up on invalidateProperties and the other methods that can help you out with this.
          With best regards,
          Barna Biro
          • 2. Re: datagrid problem
            thesteelmam Level 1
            i tried this but not success
            any help?
            • 3. Re: datagrid problem
              Barna Biro Level 3
              Hi again,
              I'll try to take a closer look at it a bit later. Until then, don't give up.
              With best regards,
              Barna Biro
              Blog: http://blog.wisebisoft.com
              • 4. Re: datagrid problem
                Barna Biro Level 3
                Ok, I'm back. Try this out:
                package
                    import flash.display.Graphics;
                    import flash.display.Shape;
                    import mx.core.FlexShape;
                    public class CustomDG extends DataGrid
                        private var _strongColor:uint = 0x9BCE49;
                        private var _fadedColor:uint = 0xC9FDC8;
        rowIndex:int,
        y:Number,
        height:Number,
        color:uint,
        dataIndex:int):void
                            var background:Shape;
                            if (rowIndex < s.numChildren)
                                background = Shape(s.getChildAt(rowIndex));
                            else
                                background = new FlexShape();
                                background.name = "background";
                                s.addChild(background);
                            background.y = y;
                            color == 0xFFFFFF ? color = _fadedColor : color = _strongColor;
                            var graphics:Graphics = background.graphics;
                            graphics.clear();
                            graphics.beginFill(color);
                            graphics.drawRect(0, 0, width, height);
                            graphics.endFill();
                I don't really have time to play around with the alpha part and make it work with a single color that is once faded and once not. I chose to play around with 2 different colors ( a strong version and a light version ). Obviously, you can play around with the alpha too, you just need to understand the mechanism behind the updating.
                With best regards,
                Barna Biro
                EDIT: I think that it's even better to use 2 different colors because this way, you have even more control over the appearance. You are not limited this way to a single color and it's faded version. You could combine 2 totally different colors ( like blue and red ).
                • 5. Re: datagrid problem
                  thesteelmam Level 1
                  thank you very much
                  i will test the code soon and i will tell u the result
                  thanx
                  • 6. Re: datagrid problem
                    thesteelmam Level 1
                    hi
                    i tested the code but i faced the same problem
                    while scrolling the colored rows can't update its colors
                    this is the changes i made in your code
                    package Models{
                         import mx.controls.Alert;
                        public class cDataGrid extends DataGrid{
                            override protected function drawRowBackground(s:Sprite,rowIndex:int,y:Number,height:Number,color:uint,dataIndex:int):void {
                                if (rowIndex < s.numChildren){
                                else{
                                background.y = y;
                                try{
                                         color = 0xffffff;
                                         color = 0xdf8b41;
                                         color = 0xa9a79f;
                                         color = 0x00ff00;
                                catch(err:Error){
                                graphics.clear();
                                graphics.endFill();
                    i used all invalidate methods but got the same result !!
                    any help doing this ?
                    thanx alot
                    • 7. Re: datagrid problem
                      Barna Biro Level 3
                      Did you even try the code I posted? I'm quite sure you didn't. When you scroll, the rows get updated correctly ( just like with the default DataGrid component ). The problem is that you are messing the whole thing up by trying to color the row depending on status. You should first read up on the DataGrid component and understand how it functions, you won't advance by copy-pasting code that you don't understand.
                      Once you read up on the component and understand how it's built to function then you'll see the problem in your code too.
                      With best regards,
                      Barna Biro
                      • 8. Re: datagrid problem
                        thesteelmam Level 1
                        thank you too much
                        i will do then come back
