7 Replies Latest reply on Oct 3, 2008 12:33 PM by Newsgroup_User
    Inserting .flv files into A web page
    Landisnetusa
      I am attempting to insert a 30 sec .flv video into one of my pages using progressive-download. I am having a problem with the playing of the video were the first two seconds play normally, but the rest plays at faster speed. Example:. Is this a reult of the flv file which is converted from a DVD?
      Thanks in advance
        • 1. Re: Inserting .flv files into A web page
          Level 7
          Landisnetusa posted in macromedia.dreamweaver:
          > Hi,
          > http://www.bowls1.com. Is this a reult of the flv file which is
          There is definitely something wrong with that file. What software
          did you use to encode the .flv?
          I couldn't repair it with flvmdi, either. I suggest converting it
          again. Change the settings slightly this time and, if that doesn't
          help, use different software.
          > Thanks in advance
          You're welcome in advance.
          Mark A. Boyd
          Keep-On-Learnin' :)
          • 2. Re: Inserting .flv files into A web page
            Landisnetusa Level 1
            Thanks Mark,
            I have tried three different apps-the free one (Prism Video Converter) is the one that I used in the example. DVDZip does not even load the files from the DVD, also Flash Video Encoder CS3 does not even load the files from the DVD.
            Russell
            • 3. Re: Inserting .flv files into A web page
              Level 7
              Rename the .vod files to .mpg2.
              --Nancy O.
              Alt-Web Design & Publishing
              www.alt-web.com
              "Landisnetusa" <webforumsuser@macromedia.com> wrote in message
              news:gaekbu$ir2$1@forums.macromedia.com...
              > Thanks Mark,
              the
              the
              DVD.
              > Thanks,
              > Russell
              • 4. Re: Inserting .flv files into A web page
                Thanks Nancy O,
                This is the first time I ever worked with video from a dvd before. Flash encoder CS3 will not convert the changed file. Gives me a message that I do not have the proper codec to do so.
                Thanks again,
                Russell
                • 5. Re: Inserting .flv files into A web page
                  Level 7
                  I use several utilities, but if you are on Windows, Alive DVD Ripper is
                  fairly reliable for converting
                  most DVD and VOB files to AVI or MPEGs. Then you would run the converted
                  files through your flash encoder.
                  http://www.alivemedia.net/
                  If you need help, contact me through my website.
                  --Nancy O.
                  www.alt-web.com
                  news:gaeugn$t97$1@forums.macromedia.com...
                  > Thanks Nancy O,
                  do
                  > Thanks again,
                  > Russell
                  • 6. Re: Inserting .flv files into A web page
                    Thanks Nancy O,
                    I purchased Alive, converted my file into mpeg, then ran it through my flash_encoder and it worked perfectly!
                    Thank you very much!
                    • 7. Re: Inserting .flv files into A web page
                      Level 7
                      You're very welcome. Glad you got it worked out. :-)
                      --Nancy O.
                      www.alt-web.com
                      news:gc5ktm$8cf$1@forums.macromedia.com...
                      > Thanks Nancy O,
