6 Replies Latest reply on May 12, 2009 1:08 PM by Fredy Gadotti
    Editable Datagrid with LabelFunction Problems
    Fredy Gadotti
      I'm having problems with a datagrid with editable columns and labelFunctions.
      The problem is that when i leave the editable field by a way that wasnt with Escape Key, the datagrid apply again the labelFunction and destroy the number formattion adding a lot of numbers.
      When the field is filled with 0000,00 he just adds more zeros, like 0.000.000,0000 and keep going after do the same process.
      And when the field has a number different of zero, he apply the labelFunction then after he remove the labelFunction. After few times it just make the number vanish and the cell goes empty.
      I read the documentation about editing cell and tryed to implement a solution to prevent the cell be edited, without sucess.
      The source code goes attached for some advice on my problem.
      Thanks, Fredy.
        • 1. Re: Editable Datagrid with LabelFunction Problems
          Barna Biro Level 3
          Hi Fredy,
          I did not run over this problem before. Could you maybe replicate the problem in a new Flex project and post the source code so we can take a look at it? I've been working with stuff like this quite intensely the couple of weeks and I didn't have "the luck" to run over this issue.
          With best regards,
          Barna Biro
          • 2. Re: Editable Datagrid with LabelFunction Problems
            Fredy Gadotti Level 1
            Well,
            the source code to test the problems is this.
            Quite simple, just to simulate the problem.
            I might this is the information necessary.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                 layout="vertical"
                 backgroundColor="white">
                 <mx:Script>
                      <![CDATA[
                           import mx.events.DataGridEventReason;
                           import mx.controls.TextInput;
                           import mx.controls.dataGridClasses.DataGridColumn;
                           import mx.formatters.NumberFormatter;
                           import mx.events.DataGridEvent;
                           import mx.collections.ArrayCollection;
                           [Bindable] private var collection:ArrayCollection = new ArrayCollection([
                                {code:1, description:"Item 1", value:0000},
                                {code:2, description:"Item 2", value:0000},
                                {code:3, description:"Item 3", value:0000},
                                {code:4, description:"Item 4", value:0000},
                                {code:5, description:"Item 5", value:0000},
                                {code:6, description:"Item 6", value:0000},
                                {code:7, description:"Item 7", value:0000}
                           private function formatter(item:Object, column:DataGridColumn):String {
                              var nf:NumberFormatter = new NumberFormatter();
                              nf.decimalSeparatorTo = ",";
                              nf.thousandsSeparatorTo = ".";
                              nf.precision = 4;
                              return nf.format(item[column.dataField]);
                         private function editEndHandler(event:DataGridEvent):void {
                            var myEditor:TextInput = TextInput(event.currentTarget.itemEditorInstance);
                            var newVal:String = myEditor.text;
                            var oldVal:String = event.currentTarget.editedItemRenderer.data[event.dataField];
                             if (event.reason == DataGridEventReason.CANCELLED ||
                                  event.reason == DataGridEventReason.OTHER) {
                                return;
                                if (oldVal == newVal) event.preventDefault();
                 </mx:Script>
                 <mx:Label text="Bug datagrid editavel com labelFunction"
                      fontSize="16"
                      fontWeight="bold" />
                 <mx:DataGrid dataProvider="{collection}"
                      editable="true"
                      itemEditEnd="editEndHandler(event)">
                      <mx:columns>
                           <mx:DataGridColumn headerText="Código"
                                dataField="code"
                                editable="false"/>
                           <mx:DataGridColumn headerText="Descrição"
                                dataField="description"
                                editable="false"/>
                           <mx:DataGridColumn headerText="Valor"
                                width="300"
                                dataField="value"
                                labelFunction="formatter"
                                editable="true"/>
                      </mx:columns>
                 </mx:DataGrid>
            </mx:Application>
            • 3. Re: Editable Datagrid with LabelFunction Problems
              Flex harUI Adobe Employee
              If you have a labelfunction you will usually need an ITEM_EDIT_END handler that customizes writing the edited data back to the data object.
              If you don't want that item to be editable, you can turn it off by handling ITEM_EDIT_BEGINNING or setting editable=false on the column.
              Also note that any custom handling of ITEM_EDIT_* events usually requires a call to event.preventDefault().
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              Blog: http://blogs.adobe.com/aharui
              • 4. Re: Editable Datagrid with LabelFunction Problems
                I solved a part of problem with some changes that i've made.
                Now there is no problem with values different of zero, when i got just number, its fine, but still have problems with zero values.
                The snippet code goes next, the bold part that was modified from the last sample.
                     layout="vertical"
                     <mx:Script>
                          <![CDATA[
                               import mx.controls.Alert;
                                    {code:1, description:"Item 1", value:4564654},
                                    {code:2, description:"Item 2", value:00000000},
                                    {code:3, description:"Item 3", value:00000000},
                                    {code:4, description:"Item 4", value:00000000},
                                    {code:5, description:"Item 5", value:00000000},
                                    {code:6, description:"Item 6", value:00000000},
                                    {code:7, description:"Item 7", value:00000000}
                               private var formatter:NumberFormatter;
                               private function formatterFunction(item:Object, column:DataGridColumn):String {
                                  if (formatter == null){
                                       formatter = new NumberFormatter();
                                       formatter.decimalSeparatorTo = ",";
                                       formatter.thousandsSeparatorTo = ".";
                                       formatter.decimalSeparatorFrom  = ",";
                                       formatter.thousandsSeparatorFrom = ".";
                                       formatter.useThousandsSeparator = true;
                                       formatter.precision = 4;
                                  return formatter.format(item[column.dataField]);
                                var newVal:Number = isNaN(Number(myEditor.text)) ? myEditor.text as Number : 0.0000;
                                var oldVal:Number = Number(event.currentTarget.editedItemRenderer.data[event.dataField]);
                                 // it solves the partial part of the problem, but still have some errors
                                 if (event.reason == DataGridEventReason.CANCELLED || event.reason == DataGridEventReason.OTHER) {
                                    return;
                                if (oldVal == newVal ) {
                                         // i've tryed this, but the itemEditor still open
                                         // if I just put 'return', still have the same problem
                                         // return;
                     </mx:Script>
                          fontSize="16"
                          editable="true"
                          <mx:columns>
                                    dataField="code"
                                    editable="false"/>
                                    editable="false"/>
                                    width="300"
                                    dataField="value"
                                    labelFunction="formatterFunction"
                                    editable="true"/>
                          </mx:columns>
                     </mx:DataGrid>
                </mx:Application>
                @Alex
                Thanks for the answer.
                I want to edit this column, but if there is no 'change' i dont want to apply again the label function and close the itemEditor.
                I've tryed to call event.preventDefault() but i dont know what to do next.
                Do you have some advice how to solve my problem?
                This is just happening when i got zero values on my datagrid =/
                Thanks all for the answers.
                • 5. Re: Editable Datagrid with LabelFunction Problems
                  You may need to call destroyItemEditor when you call preventDefault()
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  • 6. Re: Editable Datagrid with LabelFunction Problems
                              if (event.reason == DataGridEventReason.CANCELLED || event.reason == DataGridEventReason.OTHER || oldVal == newVal) {
                                grid.destroyItemEditor();
                              return;
                    Problem solved.
                    After call preventDefault, I destroy the item editor.
                    Thanks, Fredy.
