1 Reply Latest reply on May 11, 2009 12:30 PM by jendehaan
    dowloaded trial flash, but can't find it
    pls_help
      help-i downloaded trial new flash, then i went to my dowloads and clicked the exe file to intsall, which it totally appeared to being doing...it finished, no error messages....but when i go into my program files, it's not there (i did the same which dreamweaver, photoshop, and illustrator...and they all ended up in my program files...just not flash. i have windows xp.
        • 1. Re: dowloaded trial flash, but can't find it
          jendehaan Level 4
          You could try searching your harddrive for Flash.exe, and check the Add/Remove Programs list to see if it's there. If it isn't, for some reason it didn't install, and you may want to try again. It doesn't sound like the case, but if you're on a 64 bit system, note that for example Photoshop will install into Program Files, but Flash will be in Program Files (x86).
