2 Replies Latest reply: May 11, 2009 3:19 PM by skinnc RSS
    How to sort by time of creation
    skinnc Community Member
      Excuse the cross-posting on two forums -- I didn't realize Bridge has a separate forum....
      I'd like to sort a large folder full of files by the time of image creation.  Files were made of an event on several cameras and I'd like to synch them in order to create a slideshow that makes sense to the viewer/client.  Many thanks in advance for help.
        • 1. Re: How to sort by time of creation
          Omke Oudeman Community Member
          You did not mention what version you are using?
          In CS3 use the filterpanel and in top of this panel select the small icon
          with up and down arrow, in this drop down menu choose sort by date created.
          This will give you the natural sort order with date including time in hours
          minute and seconds.
          In CS4 you can also use the filter panel and choose date created from the
          list or use the path bar and click on the sort by line to choose from date
          created.
          One condition is essential for a correct sort order, the time and date set
          on the different camer's should be correct and identical
          separate forum....
          • 2. Re: How to sort by time of creation
            Thank you, Omke. That does solve the problem.  BTW, it's CS3 for me.
