2 Replies Latest reply on May 11, 2009 12:00 PM by -==cfSearching==-
    Coldfusion date format question
    funandlearning333 Level 1
      Hello All,
      I have an issue inserting date and time together into a database table from coldfusion.
      Right now, I am using <cfquery> to get records from a particular table, in which one of the field is date, and its value in the database is something like
      "2/14/2007 9:10:12 AM". I am performing insert operation into another table which has to insert this date field into the column of new table. I am doing currently as follow:
      <cfquery name="getDate" datasource="" maxrows="1">
         select date_field from table
      </cfquery>
      <cfif getDate.recordcount is not 0>
        <cfquery name="insertDate" datasource="">
          insert into table2 (date_field1) values (<cfqueryparam cfsqltype="cf_sql_date" value=#getDate.date_field#>)
        </cfquery>
      </cfif>
      The problem with this is only the date is getting inserted but not the time. How to format this.
      It would be great if somebody can reply, I am not sure if my messages are getting posted, as I posted couple of issues I had some time back, but never got any reply back.
      Thanks.
        • 1. Re: Coldfusion date format question
          ilssac Level 5
          cf_sql_date data type is only the date portion of a date-time value.
          cf_sql_time data type is only the time portion of a date-time value.
          cf_sql_timestamp data type is the full date-time value.
          • 2. Re: Coldfusion date format question
            -==cfSearching==- Level 4
            Cf_sql_date only passes the date portion of a date/time value.  Use a type that includes the date and time, like cf_sql_timestamp.  Check the documentation for your database type.
            The better way is to insert into the second table directly, using a single query.You can limit the number of results inserted by adding a where clause, or using the limit/top operators. The operator varies by database type.
            INSERT INTO Table2 (ColumnName)
            SELECT  ... ColumnName
            FROM    Table1
