2 Replies Latest reply on May 11, 2009 1:13 PM by twitskull
    Adobe Air copy from CD to hard disk
    twitskull Level 1
      I would like to copy file from CD to hard disk.
      I use
      imageFile = File.applicationStorageDirectory.resolvePath("yachtImages/");
      if (!imageFile.exists)
          imageFile.createDirectory();
      else
          Alert.show("exists");
      code above works and creates directory if not present
      now lets go to copying
      i use browseforopen and get image native path like this
      var imageFile:File = File.documentsDirectory;
      var txtFilter:FileFilter = new FileFilter("JPG Images", "*.jpg;*.jpeg");
      imageFile.browseForOpen("Open", [txtFilter]);
      lblFilename.text = "file://" + imageFile.nativePath
      But i can not find a way to copy image from cd to hard disk
      var currentImage:File = new File();
      currentImage.resolvePath(lblFilename.text);
      currentImage.copyTo(imageFile, true); // show error
      ArgumentError: Error #2004: One of the parameters is invalid.
          at Error$/throwError()
          at flash.filesystem::File/set url()
          at flash.filesystem::File()
          at flash.filesystem::File/resolvePath()
          at AddYacht/addImage()[C:\Documents and Settings\User\My Documents\Flex Builder 3\Ohashi\src\yacht.as:296]
          at AddYacht/___AddYacht_Button47_click()[C:\Documents and Settings\User\My Documents\Flex Builder 3\Ohashi\src\AddYacht.mxml:480]
      Is there any trick to do that? What am I doing wrong?
      Thnx guys
        • 1. Re: Adobe Air copy from CD to hard disk
          Muzak Level 3
          You have to listen for a select event when invoking the browseForOpen() method.
          The event will be triggered when the user actually selected a file.
          And if I'm not mistaken, File.browse() may suffice.
          private function selectFile():void {
               var imgFilter:FileFilter = new FileFilter("JPG Images", "*.jpg;*.jpeg");
               imageFile.addEventListener(Event.SELECT, imageFileSelectHandler);
               imageFile.browse([imgFilter]);
          private function imageFileSelectHandler(event:Event):void {
               var f:File = event.currentTarget as File;
               f.copyTo(File.applicationStorageDirectory.resolvePath("yachtImages/"), true);
          • 2. Re: Adobe Air copy from CD to hard disk
            twitskull Level 1
            You rock
            But i have another problem. I use this functions browse to add values to datagrid. I also save in datagrid row filename (nativepath).
            I need to have id of the last inserted database record first in order to create subfolder. I use sqlite and get last inserted ID and then create directory in folder yachtImages and then I would like to copy all files that are listed in my datagrid in my newly created dir (like yachtImages/1/).
            Is that even posible?
