8 Replies Latest reply on May 12, 2009 11:29 AM by Mrjavali
    XML attribute Undefined?!?
    Mrjavali
      Hey Flashers!!
      I need some help on the following:
      I am on AS2.0, CS4:
      i am trying to extract the following data from the XML attribute:
      <mytext>
      < text ida="Hello world!" idb= "bye World!">
      </mytext>
      Here's my AS2.0 code, i tried to load the xml attributes into the two separate dinamic text fields:
      //load css
      var styles:TextField.StyleSheet = new TextField.StyleSheet();
      styles.setStyle("a:link",{textDecoration:'underline'});
      styles.setStyle("a:hover",{color:'#FF0000'});
      _parent.home_text.styleSheet = styles;
      //load in XML
      var meuXML:XML = new XML();
      meuXML.load("xml/content.php");
      meuXML.ignoreWhite = true;
      meuXML.onLoad = function() {
      _parent.home_text.htmlText = this.childNode[0].childNodes[0].attributes.ida;
      _parent.contacts_text.htmlText = this.childNodes[0],childNode[0].attributes.idb;
      I keep getting an Undefined error...
      Anyone??
      Thanks!!
      Cheers!
        • 1. Re: XML attribute Undefined?!?
          there are several errors, both in your xml file and your actionscript.
          your text node shouldn't have a space before text and it should be closed.
          and childNode should be childNodes in both lines of actionscript.
          • 2. Re: XML attribute Undefined?!?
            Mrjavali Level 1
            Is this correct? i can't get it work anyway...
            <mytext>
            <text ida="Hello world!" idb= "bye World!"></text>
            </mytext>
            AS2.0 code:
            //load css
            //load in XML
            _parent.home_text.htmlText = this.childNodes[0].childNodes[0].attributes.ida;
            _parent.contacts_text.htmlText = this.childNodes[0],childNodes[0].attributes.idb;
            • 3. Re: XML attribute Undefined?!?
              that looks good.
              so, if that fails, check your textfields.  you probably have a path reference problem.
              what's
              trace(_parent.home_text) show in your onLoad method?
              • 4. Re: XML attribute Undefined?!?
                Mrjavali Level 1
                Well you were right Kglad, i did have a reference problem!
                So i test it and it worked!!! Even the trace show me the xml data...
                But now i have a new issue, when it comes to test it online, it keep giving me the "undefined" error...
                anyone??
                Thanks Kglad for you help so far...
                Cheers!
                • 5. Re: XML attribute Undefined?!?
                  use trace(this) other use a textfield to display "this" in your xml onLoad to see what's being loaded.
                  if your xml is not being loaded look for a case mismatch like content.XML or Content.xml
                  • 6. Re: XML attribute Undefined?!?
                    Mrjavali Level 1
                    Anyone can help me in that matter?
                    so i have on the AS code:
                    i test it locally, and it works, but when i upload it to the server...Not working anymore...
                    so i change the extension to:
                    meuXML.load("xml/content.xml");
                    And now it's working!!!
                    BUT!! (There's always a but), i need the extension to be "content.php" for the CMS.
                    Why the server can´t handle the file conten.php as a xml...
                    Anyone???
                    Thanks!
                    • 7. Re: XML attribute Undefined?!?
                      is php installled on your server?
                      • 8. Re: XML attribute Undefined?!?
                        Mrjavali Level 1
                        yes i do, i have a PHP contact form and it's working very well.
                        Seriously, i am getting mad about this...
                        Thanks for your help Kglad!!
