0 Replies Latest reply on May 11, 2009 7:59 PM by Natrixia
    missing declared association property
    Natrixia
      A fill command like so:
      <mx:Button label="Fill" click="{se.fill(entitymaps)}"/>
      In this data service:
      <mx:DataService id="se" destination="entityds"/>
      Gives the following stack trace:
      Error: Item added to destination: entityds of type: maps::EntityMap is missing declared association property: children
          at mx.data::ConcreteDataService/http://www.adobe.com/2006/flex/mx/internal::checkAssociations()[C:\depot\DataServices\bran ches\lcds26_hotfixes\frameworks\projects\data\src\mx\data\ConcreteDataService.as:2154]
          at mx.data::DataList/http://www.adobe.com/2006/flex/mx/internal::processSequence()[C:\depot\DataServices\branch es\lcds26_hotfixes\frameworks\projects\data\src\mx\data\DataList.as:2060]
          at mx.data::DataList/http://www.adobe.com/2006/flex/mx/internal::processSequenceResult()[C:\depot\DataServices\ branches\lcds26_hotfixes\frameworks\projects\data\src\mx\data\DataList.as:2284]
          at DataListRequestResponder/result()[C:\depot\DataServices\branches\lcds26_hotfixes\framewor ks\projects\data\src\mx\data\ConcreteDataService.as:7283]
          at mx.rpc::AsyncRequest/acknowledge()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\ AsyncRequest.as:74]
          at NetConnectionMessageResponder/resultHandler()[C:\autobuild\3.2.0\frameworks\projects\rpc\ src\mx\messaging\channels\NetConnectionChannel.as:515]
          at mx.messaging::MessageResponder/result()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx \messaging\MessageResponder.as:199]
      When the 'children' property of EntityMap is not declared, EntityMap looks like this:
      package maps
          import mx.collections.ArrayCollection;
          [Managed]
          [RemoteClass(alias="alex.onetomany.Entity")]
          public class {
              public function EntityMap() {}
              public var name:String;
              public var identity:String;
      Despite the fact that the entityds destination looks like this......
      <destination id="entityds">
              <properties>
                  <source>alex.onetomany.EntityAssembler</source>
                  <scope>application</scope>
                  <metadata>
                      <identity property="identity"/>
                  </metadata>
                  <network>
                      <paging enabled="false" pageSize="10" />
                  </network>
              </properties>
          </destination>
      ...the problem still seems to occour. The strangest thing is when I rename the destination from entityds to 'blah' (on the server in data-management-config.xml and on the client in my MXML file OneToManyTest.mxml) the error no longer happens.
      Questions:
      1) When exactly is the missing declared association property: supposed to appear? Is it when you add some associated property in data-management-config.xml, if so....
      2) How come it does not appear for the nodeds data service when I give it a similar children property on-to-many configuration in data-management-service.xml like so:
          <destination id="nodeds">
              <properties>
                  <source>alex.onetomany.NodeAssembler</source>
                  <metadata>
                      <one-to-many property="children" destination="nodeds"
                          load-on-demand="true"
                          read-only="true"
                          lazy="false"/>
                  </metadata>
                  <network>
                      <paging enabled="false" pageSize="1" />
                  </network>
              </properties>
          </destination>
      3) Most importantly: why does it appear for entityds and only when the destination is called entityds and nothing else.
