10 Replies Latest reply on May 12, 2009 6:48 AM by chandler124
    Script to put Datas from Database to TextInput
    chandler124 Level 1
      Hello,
      As it is said in the title, I would like to put Datas from Database to Textinput. Here's my application :
      Cliché 2009-05-12 11-55-40.tiff
      Well, what I want to do is when you click on the lines in the Datagrid, the "Nom Area" is completed by the Name in the Datagrid, the "adresse area" by the adress in the Datagrid ...
      Can someone help me ? please
      Thank you
        • 1. Re: Script to put Datas from Database to TextInput
          Michael Borbor Level 4
          What you need is to use the DG property selectedItem for instance this is an example where your DG is named myDG and you have a property in your dataProvider named Group.
          <mx:Text text="{myDG.selectedItem.Group}" />
          • 2. Re: Script to put Datas from Database to TextInput
            chandler124 Level 1
            Thank you but in text="{myDG.selectedItem.Group}" myDG means for example "Nom" so I'm trying to do text="{Nom.selectedItem.Group}" but there's an error which is : Acces to property Nom undefined. Any help ?
            Thank you
            • 3. Re: Script to put Datas from Database to TextInput
              Check the names of the dataProvider, how do you define that column in your dataGrid?
              • 4. Re: Script to put Datas from Database to TextInput
                chandler124 Level 1
                Here's my code
                <code>
                <mx:Application
                xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:fourD="http://www.4d.com/2007/mxml" layout="absolute"  viewSourceURL="srcview/index.html" backgroundGradientAlphas="[1.0,1.0]" backgroundGradientColors="[#EDE3E3, #555555]" color="#040404" height="899">
                <mx:Script>
                <![CDATA[
                import fourD.sql.*;
                import mx.controls.Alert;
                import mx.rpc.events.FaultEvent;
                import mx.rpc.events.ResultEvent;
                [Bindable]
                private var _resultSet:SQLResultSet;
                // Initialisation de la connection
                private function connectHandler(event:Event):void
                fourDSQLService.execute("SELECT * FROM clients"); }
                private function resultHandler(event:ResultEvent):void
                if(event.result != null) { _resultSet = event.result as SQLResultSet; } }
                // En cas d'erreur
                private function faultHandler(event:FaultEvent):void
                var zeError:String= "Error #" + event.fault.faultCode;
                // Message d'erreur
                Alert.show(event.fault.faultString,zeError); }
                </mx:Script>
                <!-- Declaration du serveur SQL-->
                <!-- Connection automatique au dŽmarrage de l'application (login/mdp)-->
                <!-- ImplŽmentation des fonctions -->
                <fourD:SQLService id = "fourDSQLService"
                host = "127.0.0.1"
                userName = "sqlUser"
                userPassword="sql"
                autoConnect="true"
                result = "resultHandler(event)"
                fault = "faultHandler(event)"
                connect="connectHandler(event)"
                <!-- Declare the 4D datagrid; It is also possible to use Flex embed datagrid -->
                <!-- Bind datagrid source to SQLresultSet coming from 4D-->
                <fourD:DataGrid id="contacts_dg"
                dataProvider="{_resultSet}" x="10" y="207" width="737" height="397"
                <mx:Button x="588" y="627" label="Ajouter" id="btnAjouter"/>
                <mx:Button x="666" y="627" label="Supprimer" id="btnSupprimer"/>
                <mx:Text x="10" y="10" text="Nom" />
                <mx:Text x="10" y="36" text="Secteur d'activitŽ&#xd;"/>
                <mx:Text x="10" y="62" text="Groupe"/>
                <mx:Text x="10" y="112" text="Responsable commercial"/>
                <mx:Text x="10" y="88" text="Adresse"/>
                <mx:Text x="416" y="88" text="Ville"/>
                <mx:Text x="595" y="88" text="Code Postal"/>
                <mx:Text x="10" y="138" text="Responsable production&#xd;"/>
                <mx:Text x="416" y="112" text="Responsable 3"/>
                <mx:Text x="416" y="138" text="Responsable 4"/>
                <mx:Text x="624" y="10" text="Code"/>
                <mx:RadioButton x="610" y="34" label="Client"/>
                <mx:RadioButton x="675" y="34" label="Prospect"/>
                <mx:TextInput x="48" y="8" width="568" id="nomArea" />
                <mx:TextInput x="117" y="34" width="485"/>
                <mx:TextInput x="666" y="8" width="81"/>
                <mx:TextInput x="675" y="86" width="72"/>
                <mx:TextInput x="63" y="60" width="684"/>
                <mx:ComboBox x="157" y="110" width="251"></mx:ComboBox>
                <mx:ComboBox x="157" y="140" width="251"></mx:ComboBox>
                <mx:ComboBox x="512" y="110" width="235"></mx:ComboBox>
                <mx:ComboBox x="512" y="140" width="235"></mx:ComboBox>
                <mx:Text x="317.5" y="161" text="Liste Clients" fontSize="19"/>
                <mx:TextInput x="63" y="86" width="345"/>
                <mx:TextInput x="452" y="86" width="135"/>
                </mx:Application>
                </code>
                • 5. Re: Script to put Datas from Database to TextInput
                  This is a minimal example:
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
                       <mx:Script>
                            <![CDATA[
                                 import mx.collections.ArrayCollection;
                                 [Bindable]
                                 public var expenses:ArrayCollection = new ArrayCollection([
                                      {Month:"Jan", Profit:2000, Expenses:120, Amount:45},
                                      {Month:"Feb", Profit:1000, Expenses:200, Amount:60},
                                      {Month:"Mar", Profit:1500, Expenses:500, Amount:30}
                       </mx:Script>
                       <mx:TextInput text="{myDG.selectedItem.Expenses}" />
                       <mx:DataGrid id="myDG" dataProvider="{expenses}" />
                  </mx:Application>
                  • 7. Re: Script to put Datas from Database to TextInput
                    You're welcome.
                    And this was my post 1000, Yahoo I'm going for the next 1000 posts.
                    • 8. Re: Script to put Datas from Database to TextInput
                      chandler124 Level 1
                      Congratulations Michael
                      And now I would to complete a form with Nom, Adresse ... and put it in the Database. How can I proceed ?
                      • 9. Re: Script to put Datas from Database to TextInput
                        Probably before saving the data you should validate it, using the custom validators and once it's validated. You just need to create a function, an Insert statement and send it to your SQLite DB.
                        • 10. Re: Script to put Datas from Database to TextInput
                          chandler124 Level 1
                          Well I made a "OK" button in order to validate the form. I understand that I have to associate a function to the property "click" but I don't know how to write the functions. I'm sorry I begin with ActionScript ... :s
