8 Replies Latest reply on Sep 6, 2008 12:00 AM by BKBK
    Parsing of field
    rjproctor
      I am trying to parse a field, I cannot use right or left because the item isn't in the same place. Here is an example of the field data;
      'MEISTER 56767 CB5-325-3-M-84-55 IGE 60DEG 6.5MMX14/M4.5 (G-213 MOD); FSP100:034250006500001; FSP200:RSRV-189'
      I need to get FSP100:034250006500001 from the field.
      Any ideas.
        • 1. Re: Parsing of field
          Dan Bracuk Level 5
          Your specific example is a list with semi-colons as the delimiter.
          • 2. Re: Parsing of field
            rjproctor Level 1
            Yes it is, so how do I parse the field to parse within cf to see the semi-colons
            • 3. Re: Parsing of field
              Level 7
              If one where to read some of the ColdFusion documentation concerning
              it's list functions, one would learn that all the list functions allows
              one to specify the list delimiting charatcer(s) as a parameter of the
              function.
              I.E. <cfoutput>#listLen('MEISTER 56767 CB5-325-3-M-84-55 IGE 60DEG
              6.5MMX14/M4.5 (G-213 MOD);FSP100:034250006500001; FSP200:RSRV-189',';')
              • 4. Re: Parsing of field
                rjproctor Level 1
                OK, the listlen will give me the no of semicolons, but there are multiple semicolons and the item that I need isn't always after the 3rd semicolon but it is always after the FSP100:
                • 5. Re: Parsing of field
                  Level 7
                  Then you are looking for a regular expression search using the ReFind()
                  function. A read of the documentation for ReFind() and how to use the
                  resulting structure maybe in order.
                  <cfdump var="#refind('FSP100:(.*?);','MEISTER 56767 CB5-325-3-M-84-55
                  FSP200:RSRV-189',1,true)#">
                  • 6. Parsing of field
                    davidsimms Level 1
                    See the attached.
                    • 7. Re: Parsing of field
                      Dan Bracuk Level 5
                      quote:
                      This might be the simplest way:
                      Use find to get the postition of FSP100:
                      Use RemoveChars to make FSP100: the first characters of your string
                      Use ListFirst to get the final answer.
                      Usage of all 3 functions are in the cfml reference manual. If you don't have one, the internet does.
                      • 8. Re: Parsing of field
                        BKBK Adobe Community Professional & MVP
                        Davidsimms has effectively wriiten the code for you. Oh, and don't double-post.
