9 Replies Latest reply on Nov 2, 2008 5:26 PM by Newsgroup_User
    PHP Redirect syntax error
    Level 7
      > I have 2 files I would like to redirect to after running a script.
      > Call them 'thislist.php' and 'thatlist.php'.
      > So, if $agency='this';
      > what is the correct syntax to redirect to thislist.php?
      > This gives me an unexpected T_STRING error:
      > header ("Location: ".$agency."list.php");
      > I have tried several variations, but no luck.
      > Thanks!
      > Harvey
      Actually, I may have a different problem. I get the unexpected T_STRING
      error with this as well:
      header ("Location: thislist.php");
      What am I doing wrong?
      Harvey
        • 1. Re: PHP Redirect syntax error
          Level 7
          if ($agency == 'this') {
          header("Location: ". $agency . "list.php");
          But - why do the test if the location is going to be the concatenated value
          of the $agency string with 'list.php'?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "eclipsme" <none@nowhere.com> wrote in message
          news:gekvhn$g6c$1@forums.macromedia.com...
          > > Thanks!
          > > Harvey
          > Thanks,
          > Harvey
          • 2. Re: PHP Redirect syntax error
            Level 7
            > value of the $agency string with 'list.php'?
            No, it is the concatenation that is giving me trouble. The string error
            was the result of a missing ';'. That is solved. Now everything is
            working except I am not redirected. I am left with a blank page, which
            is the script page with no output.
            I had tried the syntax you give above, but it was the ';' that was
            messing me up.
            Now, this is working, except I have to investigate changing cases. The
            variable is upper case, but in this instance, I need lower case.
            This has been an arduous learning process, but I am on the edge of victory!
            Thanks Murray.
            Harvey
            • 3. Re: PHP Redirect syntax error
              Level 7
              exit();
              news:gel5v9$o1g$1@forums.macromedia.com...
              > was the result of a missing ';'. That is solved. Now everything is working
              > except I am not redirected. I am left with a blank page, which is the
              > I had tried the syntax you give above, but it was the ';' that was messing
              > me up.
              > victory!
              > Thanks Murray.
              > Harvey
              • 4. Re: PHP Redirect syntax error
                Level 7
                eclipsme posted in macromedia.dreamweaver:
                >> concatenated value of the $agency string with 'list.php'?
                > error was the result of a missing ';'. That is solved. Now
                > everything is working except I am not redirected. I am left with a
                > blank page, which is the script page with no output.
                I have a recollection of a rush job where I had a similar problem. I
                never got the chance to discover why, but I did find a work-around that
                worked. Save the concatenation in a variable, then use that variable in
                the header() function.
                $loc = $agency. 'list.php';
                header("Location: $loc");
                Note: You should use a full URL for header(). ISTR prepending
                $_SERVER['HTTP_HOST'] for portability.
                Mark A. Boyd
                Keep-On-Learnin' :)
                • 5. Re: PHP Redirect syntax error
                  Level 7
                  Thanks. I will look into this.
                  This syntax worked perfectly for me:
                  Harvey
                  • 6. Re: PHP Redirect syntax error
                    Level 7
                    Glad to hear it.
                    Mark "alt.php" Boyd
                    Keep-On-Learnin' :)
                    • 7. Re: PHP Redirect syntax error
                      Level 7
                      Mark is correct, however. You must use a fully qualified link for the
                      redirection to comply with the letter of the law.
                      "Mark A. Boyd" <lingoboyd@mboydDotcom.invalid> wrote in message
                      news:Xns9B4A9DE0A1AB0mblistssanDotrrcom@216.104.212.96...
                      > Glad to hear it.
                      > Mark "alt.php" Boyd
                      > Keep-On-Learnin' :)
                      • 8. Re: PHP Redirect syntax error
                        Level 7
                        Murray *ACE* posted in macromedia.dreamweaver:
                        > the redirection to comply with the letter of the law.
                        Yep. I never ran into any consequences before learning about it, but
                        why take chances?
                        As a side note, Harvey, you might find that comp.lang.php is more
                        active than alt.php. And it's in one of the original "Big 8" Usenet
                        heirarchies.
                        Mark "Get Out of Jail, Free" Boyd
                        Keep-On-Learnin' :)
                        • 9. Re: PHP Redirect syntax error
                          Level 7
                          > why take chances?
                          > heirarchies.
                          Thank you Mark. I just subscribed. Years ago I swore I would not be a
                          programmer. Oh well. Here we go again!
                          Harvey
