2 Replies Latest reply on May 13, 2009 1:35 PM by davidtor2ano
    Two suggestions
    davidtor2ano
      Folks, you can get your converted files if you pick the third option for delivery: your browser. it will convert it while you wait and give you the button to retrieve it. I also suggest all of you send an email to Adobe to report the problem. I just did. You'll have to use the "other" issues tab. This is terribly frustrating and I don't think I'm going to remain a subscriber much longer.
        • 1. Re: Two suggestions
          bernronan
          Thank you for the suggestion. Could you post specific instructions on how to get pdf via our browsers.
          I've been trying --for the past five days-- to get several docs saved to pdf--w/ no luck.
          Thank you!
          • 2. Re: Two suggestions
            davidtor2ano Level 1
            Sure. After signing in with your ID and password, click on "Convert a File"
            then browse for the file you want to upload. Depending on the size, this may
            be the longest portion of your wait.
            When the next box pops up, one of the things that can be changed is the
            method of delivery. You probably already have it set to be notified by email
            when it's done. Go to that entry point and use the option to wait for the
            results in your browser (on mine it's the second option). Then click the
            appropriate button to start the process.
            You'll then have to wait for it to do the conversion, but it will then come
            up with a box that will tell you it's available and a button to retrieve it.
            Then of course, do your usual creation of a copy. Hope that help.
