11 Replies Latest reply on May 16, 2009 5:34 AM by Michael Borbor
    tlf
    thesteelmam
      hi all
      how r u
      how can i use TLF (text layout framework) with various components like datagrid, combobox or lists ?
      are there any ways to do this ?
      thanx
        • 1. Re: tlf
          Michael Borbor Level 4
          Read this great tutorial at InsideRIA
          http://www.insideria.com/2009/03/flash-text-engine.html
          • 2. Re: tlf
            thesteelmam Level 1
            thank you very much
            this is great article and was very useful
            but i want to know if the following is pissible or not
            i want to use tlf as the text properties for components for example textbox1.text=some text treated with tlf
            any help?
            thanx
            • 3. Re: tlf
              Barna Biro Level 3
              If I'm not mistaking then TLF will be available with Flex 4. Current Flex 3.x components don't support it. Try downloading the free Flex 4 SDK ( it's in beta at the moment ) and play around with it, at least you'll know how to prepare for the future.
              With best regards,
              Barna Biro
              Blog: http://blog.wisebisoft.com
              • 4. Re: tlf
                Sure you just need to go to labs.adobe.com from there you van download
                the TLF, and you'll also find instructions on how to use with Flex3.
                Actually you can download the New York Times Reader App that was just
                release using TLF.
                Sincerely,
                Michael
                El 13/05/2009, a las 6:16, thesteelmam <forums@adobe.com> escribió:
                thank you very much
                *i want to use tlf as the text properties for components for example
                textbox1.text=some text treated with tlf*
                any help?
                *thanx
                • 5. Re: tlf
                  thesteelmam Level 1
                  i know how to use it really
                  but i want to use it with flex controls like buttons and datagrids or lists
                  can i do that?
                  • 6. Re: tlf
                    thesteelmam Level 1
                    i was there from many hours really it is the best source of informations about flex
                    but iam asking about the ability using tlf with controls
                    thank you too much
                    • 7. Re: tlf
                      Currently not, you have to use the TLF components.
                      Here's another great article about it.
                      http://www.adobe.com/devnet/flex/articles/text_layout_framework_print.html
                      Sincerely,
                      Michael
                      • 8. Re: tlf
                        thesteelmam Level 1
                        hi
                        thank you for ur help
                        the article is great, to reach my goal i used this idea :
                        package Models
                             import flash.events.Event;
                             import flash.text.engine.ElementFormat;
                             import flash.text.engine.FontDescription;
                             import flash.text.engine.TextBlock;
                             import flash.text.engine.TextElement;
                             import flash.text.engine.TextLine;
                             import flashx.textLayout.formats.TextAlign;
                             import mx.controls.Label;
                             import mx.events.FlexEvent;
                             public class myLabel extends Label
                                  private var _text:String;
                                  public function myLabel()
                                       super()
                                       addEventListener(FlexEvent.VALUE_COMMIT,Text)
                                  public function get myText():String{
                                       return _text;
                                  private function Text(event:Event) : void{
                                       if(text!=""){
                                            var fd:FontDescription = new FontDescription("Tahoma","normal","normal","device","cff","horizontalStem");
                                            var ef:ElementFormat = new ElementFormat(fd);
                                            ef.fontSize=10;
                                            ef.color=584625;
                                            var te:TextElement = new TextElement(text, ef);
                                            var tb:TextBlock = new TextBlock();
                                            tb.content = te;
                                            var tl:TextLine = tb.createTextLine(null, 200);
                                            tl.x=width/2-tl.width/2;
                                            tl.y=height/2-tl.height/2;
                                            _text=text;
                                            text=""
                                            addChild(tl);
                        this is for labels and it worked well, for grids or listbase controls i set itemrenderer property to the new label class also for textinput i can use textflow component, the problem now in othe components like tabs or accordions how can i set its labels to my class or even replace its labels with tlf text?
                        another question plz : how can i make the direction of TextLine right-to-left ? in textflow there is property to do this ...
                        thanx alot
                        • 9. Re: tlf
                          In that case you can do the same thing that you did with label but
                          extending the AccordionHeader and so on.
                          Sincerely,
                          Michael
                          El 14/05/2009, a las 8:30, thesteelmam <forums@adobe.com> escribió:
                          hi
                          package Models
                                       & nbsp; super()
                                       & nbsp; addEventListener(FlexEvent.VALUE_COMMIT,Text)
                                       & nbsp; return _text;
                                       & nbsp; if(text!=""){
                                       & nbsp;      var fd:FontDescription = new
                          FontDescription(
                                       & nbsp;      var ef:ElementFormat = new
                          ElementFormat(fd);
                                       & nbsp;      ef.fontSize=10;
                                       & nbsp;      ef.color=584625;
                                       & nbsp;      var te:TextElement = new TextElement(text,
                          ef);
                                       & nbsp;      var tb:TextBlock = new TextBlock();
                                       & nbsp;      tb.content = te;
                                       & nbsp;      var tl:TextLine = tb.createTextLine(null,
                          200);
                                       & nbsp;      tl.x=width/2-tl.width/2;
                                       & nbsp;      tl.y=height/2-tl.height/2;  &
                          nbsp;            &nb sp;
                                       & nbsp;      _text=text;
                                       & nbsp;      text=""
                                       & nbsp;      addChild(tl);
                                       & nbsp; }
                          thanx alot
                          • 10. Re: tlf
                            thesteelmam Level 1
                            hi thank you for ur usefull ideas it helped me too much
                            thanx
                            • 11. Re: tlf
                              You're welcome.
