0 Replies Latest reply on May 13, 2009 8:26 AM by chameleon_chris
    Flash menu for website - sliding button issue!! HELP please.
    chameleon_chris
      Hi there,
      I have a navigation menu for a html webpage here and am having a few problems with it!
      I have limited knowledge in AS 2.0 and no clue when it comes to 3.0.
      The menu should just animate as you run along the tabs with your cursor and then open the selected webpage in the same window (_self) when a tab is clicked.
      The issues with the menu are:
      • (1) The slide out animation (as you will quickly see from the swf) jitters when the mouse is between two tabs. This 'vibrates' the two menu options until the mouse is moved.
      • (2) The getURL scripts I have placed on the first two tabs don't work properly either!
      I'M SURE THERE MUST BE A SIMPLER WAY OF ACHIEVING THIS!!
      If anyone is able to have a look at this mess I've got into and help me it would be greatly appreciated - I think I'm almost there.
      swf attached and fla available here:
      http://www.chameleondm.co.uk/files/flash/menusystem.fla
      As they say - a little knowledge can be very dangerous
      Cheers
      Chris
