3 Replies Latest reply on May 13, 2009 12:16 PM by -==cfSearching==-
    Formatted Data Labels in CFCHART
    mohadi Level 1
      Is there a way to format data values in CFCHART?
      All my values in database are stored as 99.9 See below). These are percentages that I need to display on a bar chart. Everything works fine except when displaying 76.0, it shows as 76. All other values that have a number besides zero after the decimal point show up fine except for zero. I want the numbers to be consistent. I am already using custom XML file for formatting but unable to display the "zero" after the decimal point.
      Let's assume, StartYear = 2007 and EndYear = 2008, and the data in Influencer_Data table looks like this:
      ID      Poll_Year     Company    Influence_ID      Pulse      Goal
      96      2008            XYZ            842                  59.6      59.6
      97      2008            XYZ            839                  80.8      80.8
      98      2008            XYZ            838                  86.9      86.9
      99      2008            XYZ            841                  67.1      67.1
      100    2008            XYZ            840                  66.3      66.3
      101    2008            XYZ            470                  54.5      54.5
      102    2007            XYZ            842                  56.5      56.5
      103    2007            XYZ            839                  81.5      81.5
      104    2007            XYZ            838                  85.5      85.5
      105    2007            XYZ            841                  71.2      71.2
      106    2007            XYZ            840                  76.0      76.0
      107    2007            XYZ            470                  54.2      54.2
      108    2008            XYZ            843                  82.6      82.6
      And the data in influencers table looks like this:
      Influencer_ID Influencer_Type
      470      Regulators
      838      Financial Community
      839      Community Leaders
      840      Media
      841      Government
      842      Advocates
      843      Mexico
      <cfloop index="i" from="#StartYear#" to="#EndYear#" step="1">
           <CFQUERY NAME="GetInfluenceData#i#" DATASOURCE="#RMIDSN#">
                Select     ID.*, I.Influencer_Type
                From     Influencer_Data ID
                     INNER JOIN Influencers I ON ID.Influencer_ID = I.Influencer_ID
                Where     ID.Poll_Year = <cfqueryparam value="#i#" cfsqltype="CF_SQL_INTEGER">
                      AND ID.Company = 'XYZ'
                Order     By I.Influencer_Type
           </CFQUERY>
      </cfloop>
      The custom XML file (TLRIS.xml) looks like this:
      ?xml version="1.0" encoding="UTF-8"?>
      <frameChart isInterpolated="false">
                <frame xDepth="4" yDepth="5" outline="black" isVGridVisible="true"/>
                <xAxis>
                     <labelFormat pattern="#0.0"/>
                </xAxis>
                <yAxis>
                     <labelStyle orientation="Horizontal"/>
                </yAxis>
                <dataLabels style="Value" font="Arial-12" isMultiline="true">
                <![CDATA[ $(value) ]]>
                </dataLabels>
                <legend allowSpan="true" equalCols="false" isMultiline="true"/>
                <elements drawOutline="false">
                     <morph morph="Grow"/>
                </elements>
                <popup decoration="Round"/>
                <paint palette="Fiesta" paint="Plain" isVertical="true" min="47" max="83"/>
                <insets right="5"/>
      </frameChart>
      And the code for the graph is below:
      <cfoutput>
      <cfchart format="#ChartType#"
           chartheight="300"
           chartwidth="750"
           scalefrom="0"
           scaleto="100"
           foregroundcolor="##000000"
           databackgroundcolor="##ffffff"
           font="Arial"
           fontsize="10"
           labelformat="number"
           style="TLRIS.xml"
           show3d="yes"
           showlegend="yes"
           tipstyle="mouseOver"
           tipbgcolor="##FFFF00">
                <cfset LoopCount = LoopCount + 1>
                <cfset WhichColor = ListGetAt(colorlist, LoopCount)>
                <cfchartseries
                            type="bar"
                           serieslabel="#i#"
                           seriescolor="#WhichColor#"
                           datalabelstyle="pattern">
                           <cfloop query="GetInfluenceData#i#">
                                      <cfchartdata item="#Influencer_Type#" value="#Pulse#">
                           </cfloop>
                </cfchartseries>
           </cfloop>
      </cfchart>
      </cfoutput>
        • 1. Re: Formatted Data Labels in CFCHART
          -==cfSearching==- Level 4
          In your xml file, try using a "pattern" for the yAxis label, and tweak the zeroes in the mask.
          <yAxis ...>
          <labelFormat style="Pattern" pattern="#,##0.0#"/>
          </yAxis>
          • 2. Re: Formatted Data Labels in CFCHART
            mohadi Level 1
            I have already done that with no success.
            I am beginning to believe this may be a bug.
            Even if you try something as simple as the following, the decimal points that have zeroes don't show
            <cfchart style="beige">
            <cfchartseries type="pie">
            <cfchartdata item="New car sales" value="50.0">
            <cfchartdata item="Used car sales" value="55.0">
            <cfchartdata item="Leasing" value="56.5">
            <cfchartdata item="Service" value="76.2">
            </cfchartseries>
            </cfchart>
            • 3. Re: Formatted Data Labels in CFCHART
              </cfchartseries>
              </cfchart>
              Well that is the wrong kind of chart and it is not using the xml style.  But it works perfectly with a bar chart, using a custom style. The values display exactly as you have them above.
              <cfchart style="myPatternStyle.xml">
                  <cfchartseries type="bar">
                  </cfchartseries>
              </cfchart>
              <!--- snippet from xml styles --->
              .... other xml ....
              <yAxis scaleMin="0">
                    <titleStyle font="Arial-12-bold"/>
                    <dateTimeStyle majorUnit="Year" minorUnit="Month"/>
                    <labelFormat style="Pattern" pattern="#,##0.0#######"/>
              </yAxis>
              .... other xml ....
