5 Replies Latest reply on May 13, 2009 1:57 PM by BennyBeta
    last line of textarea
    ShaF10
      Hi Guys
      Is there any way I can get the last line of a fixed size textarea ?
        • 1. Re: last line of textarea
          BennyBeta Level 4
          This should do it:
          // get the textArea's textField
          use namespace mx_internal;
          var textField:IUITextField = textArea.getTextField();
          // get the number of lines in the textArea
          var numLines:Number = textField.numLines
          // get the last line of text
          var lastLine:String = textField.getLineText( numLines-1 );
          Let me know if that does the trick...
          Ben Edwards
          • 2. Re: last line of textarea
            ShaF10 Level 1
            Thanks, that works, there are afew problems through.
            1. For some strange reason I need to press the right arrow key for the code to read the last line.
            2. I have written a function to remove the text from the last line. Is there a better way I could have coded it ?
            Please take a look at the code below (note: this is a simplified version of the actual code):
            private function taKeyDownHandler(event:KeyboardEvent):void {
                var ta:TextArea = event.currentTarget as TextArea;
                var taCurrent:TextArea = null;
                var taIndex:int = 0;
                var taNext:TextArea = null;
                // create new textarea if one not found
                if(!(taNext is TextArea)) {
                    taNew(); // create new textarea
                // or append current textarea lastline to next textarea's firstline
                else {
                    var textField:IUITextField = ta.getTextField();
                    var numLines:Number = textField.numLines;
                    var lastLine:String = textField.getLineText(numLines - 1);
                    // get next textarea
                    taCurrent = event.currentTarget as TextArea;
                    taIndex = taContainer.getChildIndex(taCurrent);
                    taNext = taContainer.getChildAt(taIndex + 1) as TextArea;
                    // Concatenate lastline to firstline of next textarae
                    taNext.text = (lastLine + taNext.text)
                    // remove lastline from predeccesor textarea
                    ta.text = str_replace("", lastLine, ta.text);
            private function str_replace( replace_with:String, replace:String, original:String ):String {
                 return original.replace(replace, replace_with)
            • 3. Re: last line of textarea
              BennyBeta Level 4
              I'm not sure why you are using the keyDown event, maybe try listening for the "change" event.
              A better way to remove the last line, maybe try removing the last x characters of the textArea.text where x is the length of the last line.
              • 4. Re: last line of textarea
                ShaF10 Level 1
                I was listening for certain keycodes.
                Can you give me an example of how you would implement it ?
                • 5. Re: last line of textarea
                  BennyBeta Level 4
                  Try this:
                  ta.text = ta.text.substr( 0, ta.text.length-lastLine.length );
